SD Triple Shot
Discussion in 'Just Pickups' started by ramonet, Jul 28, 2021.
  1. ramonet
    ramonet Tele-Meister
    Barcelona - Spain
    In my next build I'm planning to use the SD Triple Shot humbucker rings; anyone of you have used them? they must be used with SD pickups or any 4 wires pup will be good (taking care of every brand own colour code)?
  2. G.Rotten
    G.Rotten Tele-Afflicted
    CoolsVille
    I have a couple sets I use with Duncan P-Rails. They can be used with any 4 wire pickups though. Being able to choose series vs parallel wiring without push/pulls is nice
  3. ramonet
    Barcelona - Spain
    Thanks, I'm planing switch single / hb with one switch and series / parallel with the other. I think it's what they did, isn't it?
  4. G.Rotten
    CoolsVille
    If you know what you're doing you can likely do anything you want with them.
    I followed the diagram as made for the P-Rails and I can choose series, parallel and then tap for for either coil. So 4 different sounds in each pickup. For the P-Rails each coil is a different design so you do get 4 completely different sounds. I'm not sure how effective it would be on a Standard style HB.
    The way I have it both switches work together but I really don't know the specifics.
    Here's an example.
    Both switches slid to the left has only the left coil on, both to the right has only the right coil on.
    Both switches toward center is parallel HB and both to the outside is series HB.
  5. Zepfan
    Horn Lake, MS
    For a standard 4 wire HB, the series/parallel would be good to have.
    Switching to either coil wouldn't be much different from each other unless the coils weren't balanced, but this allows in phase/out of phase choices when picking coils to pair with from the other pickup in the middle switch position.
