Palaver
I'm at an impasse swapping out my pickups for an SD Tapped Tele set. I bought it several years ago and it sat in a drawer. Came with a 5way switch. The included info/diagram was for different pickups. So, checked the diagrams on the SD website. There are two Tapped Tele specific diagrams. they're both the same except one has a red lead instead of yellow. I made identical connections, but the results were frustrating because the last position on the selector gives no sound. I'm going to undo my work and start over while looking for whatever I missed. Loads of diagrams for 3 & 4 way switches, but I want to use the 5way.
If anyone has gone through this, Please let me know what gives here. I thought it was odd that all 3 of the hot leads from both pickups were soldered one after another on one side of the switch lugs, with one lead to the volume pot.
This is going into my 52 reissue Fender Tele. I was surprised no ground between the two pots. The other diagram I referred to shows one. I've done some of the simple steps like reversing the direction of the switch. Using the lugs on the opposite side. Currently it reflects the connections shown above.
Thanks in advance for any help anyone can give.
