Scratchy blackface bandmaster
Discussion in 'Amp Tech Center' started by nasdak, Jan 26, 2019.
  1. nasdak
    nasdak Tele-Meister
    france
    Hi folks,
    i'm having a hard time with a vintage BF bandmaster !
    I changed all the electrolytics : filter caps, bias cap, cathode caps.
    tubes are new and biased. i tryed different preamp tubes.
    pots have been cleaned with deoxit.
    All coupling capacitors have been checked for leakage and value - they are ok, and only a few mV passing trough on the circuit.
    The amps works great, trem is good. All resistors are stock.
    BUT my 2 vol pots are scratchy and i without touching the pots i get an intermitent "scratch scractch" that does not seem to be related to volume. it come and goes. i tried to swap some resistors (plate load of V1, V2 and PI) with no luck. I even tried new coupling caps at some places, no luck. I don't want to check every component, i'd like to keep the original soldering...
    Any thought? it's driving me crazy !
  2. dogmeat
    dogmeat Tele-Afflicted
    Alaska
    start poking things with a chopstick
  3. Wally
    Try reflowing the solder joints on those pots. Cold solder joints can cause that scratch.
  4. DADGAD
    DADGAD Friend of Leo's
    Earth
    A couple of more maintenance items for old amps is to retention the tube sockets and retighten all jacks and potentiometers to make sure they are well grounded.
  5. nasdak
    nasdak Tele-Meister
    france
    I'll try the pots solder joints but i think i've done them already
    i poked all i could poke with my favorite chopstick of course, nothing (only microphonic wires going to grid of V1 and V2 but it often happens)
    Wally likes this.
  6. nasdak
    nasdak Tele-Meister
    france
    thx. did that already. will recheck :)
  7. Wally
    Okay...scratch even when not turning the pots. Do you get the scratch when you ARE turning the pots.
    Both channels......that seems odd.
  8. nasdak
    nasdak Tele-Meister
    france
    i don't mind the scratchy pots (the're 50 years old...)
    but i do mind the intermitent scratch scratch... i have a scope, i tried to follow the signal, but that scratch is to weak, can't see it on the scope :/
  9. nasdak
    nasdak Tele-Meister
    france
    Some update...
    Well it seems a change of PI tube did the trick :D
    And a second pass of deoxit helped with the pots.
    Sometimes it's too simple!!!
    Envoyé de mon Redmi 4X en utilisant Tapatalk
    robrob, corliss1 and Wally like this.
