Whatizitman
I'm new to the strat world. I absolutely love the neck! I've never felt a neck so comfortable and playable.
That's where the fun ends, and the work begins, though. I'm coming from a lifetime of a tele with stock hot pickups, and gibsons and epiphones with humbuckers and p90s. Basically set up to rock in some form or another, I guess.
I really didn't think I would be stepping into another world. Boy, was I wrong.
I'm having difficulty getting used to the pickups in particular. But the frets might need a little dressing, too. Basically, there is almost no sustain higher up on the neck. I first tried raising the pickups, but that didn't help. Stratitis and all. I lowered them to back around spec or lower, and it's better that way. The output is just so low that I can't drive the amp the way I'm used to. Adding a lot of drive with pedals adds some compression/sustain. But sounds like mud.
I'll continue to dial in the relief, string height, and/or frets if need be. But I'm assuming at this point that the sustain and output aren't going to get significantly better just by getting a few high frets leveled out (it doesn't need a full dress).
Is this just the nature of strats? Current MIMs have vintage style, lower output pickups, right? I'd rather not go down the pickup rabbit hole, if I can avoid it. Nor do I want the guitar to only be for clean quack. OTOH, I would like to expand my playing into more appropriate strat genres. Any suggestions?
