Scoop control?
Discussion in 'Shock Brother's DIY Amps' started by laird, Aug 7, 2009.
  1. laird
    laird Tele-Holic
    Palm Harbor, FL
    I'm looking to make a 1-knob variable scoop control. This is going into a Vox-like EF86 preamp inbetween the "brilliance" adjustable HPF and a 500ka volume control. After a very impatient look around various archives I couldn't find anything that looked promising. So I came up with a simple design (not yet tested) that I think will work, give or take capacitor value tweaks to get the right frequency range. I'm too lazy to draw a diagram but it's very simple, just 4 components...
    Start with one 500K linear dual-gang pot, we'll call the gangs A and B.
    Input signal goes to A lug 1.
    A 100pf cap goes from A lug 1 to B lug 3
    A lug 2 connects to B lug 1
    A 50K resistor connects A lug 3 to A lug 2
    A .01uf cap connects A lug 3 to ground
    Output signal comes from B lug 2
    I can't figure out how to use LTspice to model this. Does anyone have any experience with passive scoop controls? Does this seem like it would work?
    -Laird
  2. celeste
    celeste Friend of Leo's
    Maryland
    How about making the slope resistor of a typical TMB stack a pot.
  3. laird
    laird Tele-Holic
    Palm Harbor, FL
    This preamp doesn't have a tone stack, thus no slope resistor.
    The design above is kind of a stripped-down Vox tone stack... Imagine the slope resistor and treble as the two gangs of the pot, the bass cap jumpered, and the bass pot removed. The treble cap controls the highs passed through and the mid cap controls the roll-off frequency that makes the scoop. The midrange resistor functions as a sort of scoop depth control.
    -Laird
  4. JD0x0
    JD0x0 Poster Extraordinaire
    New York
    i forgot the website but they make a passive scoop control for guitar, could work for an amp just as well im assuming
  5. teleamp
    teleamp Poster Extraordinaire
    Prairie Hill, Texas
    Basically what you have is a tone stack with fixed values instead of pots.
    Replace the midrange resistor with a 25K ohm audio taper pot and see what that does for you.
  6. FenderLover
    Minnesota
    I can't help with the design details, but you could also Google for the Matchless Cheiftain schematic (duncanamps.com) and look at that circuit.
    The Bass and mid are separate circuits, sandwiched between the first two stages.
  7. laird
    laird Tele-Holic
    Palm Harbor, FL
    The Chieftain's mid control looks like the winner! Using Duncan's Tone Stack Calc I simulated it and my circuit:
    The Chieftain is in blue, mine in purple. It maintains less signal loss and it's easier to focus the frequencies it affects with simple component replacement.
    Thanks FenderLover, you hit the nail right on the head!
    -Laird
  8. FenderLover
    Minnesota
    Your welcomed, Laird.
    My Cheiftain sounds great too. There are a few cool circuit ideas from that amp that I've copied, so I'm glad to pass something on.
