Schumacher PT in a Sound City??? True identity???
Discussion in 'Amp Tech Center' started by Huddy, May 21, 2020.
  1. Huddy
    Huddy Tele-Holic
    Newport News, VA
    066F3466-92CF-4426-8C01-210B1B4BFD27.jpeg Can anyone identify this power transformer? It’s in a Sound City 50 Plus currently. Wondering what it could have come out of or what it was designed for.
    606 is Schumacher and it’s got a black and white primary with the normal fender-y secondaries - no CT 6.3, yellow tapped off assuming that a 5v winding, two reds and a yellow with red stripe. The a bias tap that’s red with a blue stripe.
    I’m getting ready to dig in with the multi-meter in a few. Hopefully I’ll have some more clues.
    Thanks in advance!
  2. Huddy
    Huddy Tele-Holic
    Newport News, VA
    So I'm thinking this is a Deluxe Reverb power transformer - don't know how it was powering two el34s and 4 12ax7s.
  3. schmee
    measure the mounting bolt spacing, fairly easy to narrow down if it's a guitar amp trans with that.
  4. Huddy
    Huddy Tele-Holic
    Newport News, VA
    Well I was up pretty late last night googling and I’m all but certain it’s a Deluxe Reverb power transformer either 67 or 77. The 025130 is a fender part number. I’m not sure what the L denotes. Also disconnected it and sure enough it’s 370-0-370 @ 120 with a 50 volt bias tap. The other secondaries are 6.7 and 5.3 which are spot on unloaded.
    the really odd thing is - when it was installed in the sound city amp - the HT winding was hooked up with the center tap and one side of the winding. The other end of the HT was just tapped off along with the 5v.
    I’m kinda baffled by how the amp was working as it was.
