schwa
Hey, tele people,
I've found myself in possession of a Squier tele, and it's become the only electric I play. The problem is that it has a humbucker in the bridge.
I like the sound of the humbucker on its own, especially for the louder rock I sometimes play, but switching between the neck single coil and the bridge humbucker feels unnatural-- like the two sounds don't belong to the same voice. The humbucker always feels too dark, which I can deal with with EQ/ tone knob, and too compressed, which I can't. (I know there's some debate about whether pickups can technically be more or less compressed, but from a subjective perspective, the humbucker seems to have a smaller dynamic range than the SC. It doesn't clean up as well, and doesn't seem to translate as much right hand pressure into volume.)
The obvious solution is to throw a HB sized SC in the bridge, but some of the venues I play make hum-cancelling a necessity. I've tried throwing a bright HB in the neck for a better match-- no dice. Can't do without the neck single coil. I've switched to the brightest, lowest output HB I've got (a DiMarzio Air Classic Neck is currently in the bridge position), I've lowered the pickup and brought the pole pieces up, I've turned the bass all the way down on the amp (a '65 Bandmaster-- not a muddy amp by any means,) and yet the mud and compression persists.
Before I resort to drastic measures and route the damn thing for a tele bridge, are there any miracle cures I haven't mentioned? I'm open to new pickups, creative wiring, homeopathic creams... Thanks, all!
