Sagging Gate
Discussion in 'Bad Dog Cafe' started by Mr powers, Apr 10, 2021.
  1. Mr powers
    Mr powers Tele-Meister
    Does anyone have a solution for sagging gates?
    Please and Thanks
    These gates were like these when my daughter bought her place.
  2. otterhound
    otterhound Poster Extraordinaire
    Manheim Pa.
    Poor design and quality . You may want to try a tensioned truss wire from the top of each leaf at the hinge end to the opposite corner , but I would replace them with properly constructed leafs . After 43 years in the fence business , I am willing to declare myself an authority .
    swervinbob, getbent, 1955 and 8 others like this.
  3. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    You can buy a gate brace. They're available in different lengths, and have a turnbuckle in the center. You attach them to the gate diagaonally corner to corner; the high end goes on the hinge side and the low end goes on the swinging side.
    Here's a cable type:
    https://www.homedepot.com/p/Everbilt-Anti-Sag-Gate-Kit-15469/202042235
    These work only when the hinge post is solid in the ground and the hinges are all tight and not worn. If the hinge post is out of plumb, fix that first. If the hinges are worn or broken, fix them second. Then brace the sagging gate.
  4. Mr powers
    Thank you Peegoo and Otterhound
  5. tanplastic
    tanplastic Tele-Holic
    I can see your house from here.
    Those are heavy gates with no proper corner-to-corner support.
    That design will never be stable.
    Fretting out likes this.
  6. TwangToInfinity
    TwangToInfinity Tele-Afflicted
    Twangville
    a caster mounted wheel on there
    Flip G likes this.
  7. schmee
    schmee Doctor of Teleocity
    Two fixes:
    -Add a wheel on the bottom, common with big gates.
    -Add a post on the hinge end and a guy wire attached to the post then to the gate end with a cheap turnbuckle.
    Can't see the posts though... are they big? Sturdy? Set in concrete?
    Torren61 likes this.
  8. Mike_LA
    Mike_LA Tele-Afflicted
    Just past 11 on the Dial
    Proper post sunk into the ground with cement, Wire rope cable from top of post to the lower center point of the gate, both sides.
    With a good anchor point you can support the gate
    getbent and Torren61 like this.
  9. Mr powers
    I'll have to redo the poles.
    They are not anchored in cement.
    carpenter likes this.
  10. Peegoo
    If you decide to install adjustable gate braces, this is where the anchors will go on your gates:
    Harry Styron and Mr powers like this.
  11. ce24
    ce24 Poster Extraordinaire
    Idahoastan
    I would deconstruct.....rebuild.....none of the slats are even etc.....otherwise you will have a good swinging ugly gate.
    Mr powers likes this.
  12. Killing Floor
    Killing Floor Friend of Leo's
    Austin, TX
    I built a gate across my driveway and cut slight angles on end posts. It took about 3 days for it to sag to level. It started about 1.5 degrees high inside.
  13. Guitarzan
    Guitarzan Poster Extraordinaire
    Hotlanta, GA
    She needs to sell that place and buy a nicer one with gates that do not sag.
    Problem solved.
    You are welcome. ;):D:D
    NoTeleBob and Mr powers like this.
  14. Torren61
    Torren61 Poster Extraordinaire Gold Supporter
    Humboldt County, CA
    I built my gate like this with a hardware kit from Home Depot. I know my carpentry skills are crap. Everything is level though. Those posts are 6X6 and three feet in the ground in concrete.
    OldDude2 and Mr powers like this.
  15. NoTeleBob
    NoTeleBob Tele-Holic
    Southwestern, USA
    Rough gravel driveway.
  16. Dan German
    Dan German Doctor of Teleocity
    Left of the Left Coast
    Is that what the kids are calling it these days?
  17. otterhound
    Manheim Pa.
    Canadian ice and snow will relegate them to useless with a support caster .
  18. Harry Styron
    Harry Styron Friend of Leo's Gold Supporter
    Branson, Mo
    Well, you could snap a level chalk line across the bottom and trim along the line to achieve a uniform bottom line. Then make a parallel line for the top.
  19. Jupiter
    Jupiter Telefied Ad Free Member
    Osaka, Japan
    Milspec! What are ya tryna keep out? (Or in??) :D
  20. 1955
    1955 Doctor of Teleocity
    Sagging gait.
