S1 Switch Question
Discussion in 'Tele-Technical' started by Backbeat8, Aug 3, 2018.
Tags:
  1. Backbeat8
    Backbeat8 Tele-Holic
    I want to get rid of the entire S1 switch and "system" is that something difficult to do? How easy is this? Can I just get someone to tear the whole thing out? And then put a normal knob there instead? Or does Fender make that an extra difficult affair to participate in....
    The S1 Switch was a huge turnoff for me when I was considering the Deluxe Series, and it is now appearing to be just a massive vulnerability on an Elite model.
  2. AAT65
    AAT65 Poster Extraordinaire
    West Lothian, Scotland
    It won’t be a problem at all — just get a normal A250K pot and rewire the 3-way switch like a ‘normal’ Tele. It’s not really a “system”, just a 4PDT stuck on to the bottom of the volume pot.
    You’ll need a new barrel knob too.
    Has your S1 failed? Mine is still going strong after 2 years.
    Backbeat8 likes this.
  3. Backbeat8
    Ok! Thanks you!
    I thought it was connected in some "web of wires" to multiple places, because it affects both pups and how they work....
    I am contemplating buying the Elite Tele, but I have seen an instance where the switch becomes faulty and is apparently very fragile, and proned to causing problems or not working.
  4. voskarp
    voskarp Tele-Holic
    Uppsala, Sweden
    You don't need a "normal" pot, just a standard barrel knob on it and ignore the function (it should be standard without the switch activated).
  5. voskarp
    voskarp Tele-Holic
    Uppsala, Sweden
    ...or if you think it's bad mojo, get someone to rewire and put in a new "normal" pot...
  6. AAT65
    Good point! Keep it simple...
  7. voskarp
    voskarp Tele-Holic
    Uppsala, Sweden
    It's quite easy if you got some soldering skills and download a wiring scheme.
    I did it the other way around, took out the stock pots and put some with S-1 switches in, but I'm definitely not normal!
    :D
  8. AAT65
