Rutter-ed my b-bender
Discussion in 'B-Bender Forum' started by tigertail, Jan 31, 2020.
  1. tigertail
    tigertail TDPRI Member
    Calgary, Alberta, Canada
    Success! I ordered a modern bridge from Rutters, so I could switch from 6 saddles to the 3 saddle barrel setup. It's drilled for both top-loading and string-through, which is pretty cool. The b-string hole lined up perfectly.
    I'm really liking the change in string tension - I just couldn't really get down with the 6 saddle thing.
    Anyhow, if anyone else is considering doing this mod, I can vouch for going the Rutters route.
  2. brookdalebill
    Austin, Tx
    Very cool!
  3. Don Miller
    Don Miller Tele-Afflicted
    Anchorage, Alaska
    That looks like its made to fit an American standard style guitar (the Nashville b bender is a derivative of the American Standard design), with the dimensions different than on a vintage style guitar....which is pretty cool...
  4. T Prior
    T Prior Poster Extraordinaire
    Charlotte NC
    Looks good !
    Can you explain how the B string tension changed , its still being pulled from the PG string tower across the saddle
    curious is all.
    On my PG I pulled the standard B saddle and replaced it with a roller saddle . I don't think the tension changed but the metal to metal changed. The wear factor.
  5. tigertail
    Sorry for not seeing this until now. I wasn't super clear - I didn't see a change in the b-string tension - but overall, I found the strings a little looser going from the 6-saddle setup to the 3-barrel saddle setup. This could be in my head - I just really prefer the feel of the vintage 3-barrels to the modern 6-saddle.
  6. Mur
    Mur Tele-Afflicted
    Yep I like that better.
