Running Two Amps w/ABY Box - 1 Clean and 1 Wet
Discussion in 'Amp Tech Center' started by Butch Snyder, Sep 15, 2021.
Tags:
  1. Butch Snyder
    Butch Snyder Tele-Afflicted
    St Augustine, FL
    I have an ABY box and I would like to use it to run two amps. That's the easy part. I would like one amp to be dry and the other wet. In other words, I want all my effects going through one amp and the other amp, dry. That's the hard mart. Can't figure out how to run the cables. I have a Fender ABY box.
  2. Nogoodnamesleft
    Nogoodnamesleft Tele-Meister Silver Supporter
    Canaduh
    You’d need to put the ABY box at the front of your signal chain. A to dry and B through the pedals/effects to the wet amp.
    This is a fun experience. You can get some really cool textures depending on the amps used.
  3. willholt92
    willholt92 Tele-Meister
    Sheffield UK
    I do this.
    Easy.
    ABY as the first in your chain seen here on the right hand side of my board.
    B output plugged straight into my Princeton/Champ build. (Sometimes through the Treble booster on top)
    A output then goes to my Tone bender and through the rest of my board into the Blackstar.
    Nogoodnamesleft likes this.
  4. schmee
    Yeah, you simply run the guitar to the ABY box, then run A out to the clean amp and B out to the pedal board then to the wet amp.
    What you may find though is it can be noisy..... as some amps dont play well together.
  5. Si G X
    Si G X Tele-Afflicted
    England
    Put all your effects in the 'A' Path to one amp and leave the 'B' path straight to the other amp.... run as a 'Y'. Simple!
  6. Nogoodnamesleft
    Canaduh
    Meant to add or vice versa. Also it’s really fun to add a volume control in there (I like in the dry signal path) to add some mix control in the setup.
  7. Willie Johnson
    Willie Johnson Tele-Afflicted
    Chicagoland
    I have a passive aby box (LiveWire, which I think is the same as the Fender but with a different logo) but swapped it instead for a LPB-1 (set just a hair past unity gain) and a Y plug in the out jack. Each chain get a couple of overdrive/coloration pedals. Chain 1 also gets eq and the goes to a PRRI with onboard reverb and trem. After OD, chain 2 gets echo/delay, a combo boost/reverb, and then goes to a 70's Princeton non-reverb. That one will also get a graphic eq before delay soon. I've gone back and forth with the delay, and think it sounds better going to the second amp--more three-dimensional. Any critiques of that approach?
  8. Butch Snyder
    St Augustine, FL
    I think I might need a diagram. Here's what I have going to my amps. I want to ME-50 going only to one amp.
  9. Butch Snyder
    St Augustine, FL
    Figured it out. Had to move my APY box to sit on the right side of the ME-50; then it made sense.
  10. muscmp
    muscmp Friend of Leo's
    california
    not to add to any possible confusion but you could set up a stereo routing to take advantage of the boss unit. guitar to boss input and L and R outs to amps. no need for aby pedal in that configuration. try it and you may like it.
    play music!
  11. ce24
    ce24 Poster Extraordinaire
    Idahoastan
    Love the ME series…i have the ME50 and the ME80….great fx units.
    Butch Snyder likes this.
  12. Dostradamas
    Dostradamas Tele-Holic
    Oregon
    Guitar - Tuner - ABY
    A-Champ dry
    B-Front pedals - Trademark 30 input - loop pedals
