Boreas
Thanks! That is definitely true. I tried swapping leads and it REALLY got weird. So it is actually wired right. I think it is just the nature of the beast. All is good now that I am used to it. Luckily I put in a linear tone pot, so I have allotta room to adjust tone. After getting a better balance with heights, it isn't quite as obnoxious, but if you are not used to it, the bridge tone takes a little getting used to. If I do another with P90s, I will try to move the bridge pickup closer to the neck.I don’t think anyone has mentioned this. You described the issue as not enough volume in the bridge and that it quacks instead of sings. I had a similar issue with a GFS dream 90. I know it’s not a traditional P90. In my case, I had wires the bridge out of phase which made it quack like the strat in between sound. Try reversing the bridge pickup leads. That did the trick for me. A bridge p90 shouldn’t quack and should give you tons of volume and grit.
