Routing acrylic (with a CNC)
Discussion in 'Tele Home Depot' started by thecableguy, Jan 28, 2015.
  1. thecableguy
    thecableguy Friend of Leo's
    Sherwood Park, Canada
    So I picked up a 4x4 sheet of 1/4" cast acrylic. I'm going to use it to make a dust shoe for my CNC as well as some guitar building templates for a guy I know. I've read some conflicting stuff online (shocking, I know) about machining the stuff. The cast stuff I got is better for machining than the extruded variety because it's more rigid, so that's a good start. Has anyone here routed acrylic before? Any cutter, rpm and feedrate recommendations? I'm not looking for a glass finish on the cuts but I obviously need smooth cuts if I'm going to cut templates.
  2. KWhatley
    KWhatley Tele-Holic
    London, UK
    My experience of routing plastics is treat it like your final passes on a neck/body. E.g least amount you can leave to route off the better. Other than that ventilation and a fume filtering mask. Gave me headaches for days mate. Rpm was usual recommended for anything under 1" dia and feed rate I'd discribe as smooth flowing like it was wood, not stopping and making it melt. Hope that helps.
    Edit . I cut it close to dimensions on a bandsaw or with a jigsaw prior to routing.
    Edit 2. This man flu's in overdrive since it's made me oblivious to the cnc part of the title :oops:
    I'll just go hide in a corner until I'm better I think.
  3. guitarbuilder
    I did a double neck pickguard but have no specs. Usually I run at 50 ipm and start out at half that rate and slowly increase as necessary. With mach it's just a matter of clicking on an arrow.
    I'd suggest you just pick a bit and try some samples at different rates.
  4. Nick JD
    Queensland, Australia
    A handy hint for routing acrylic: buy some super-thin plastic sheeting (like a painter's dropsheet) and just before you start routing, unfold the sheet and position it on the "downwind" side.
    The static electricity sucks all the acrylic flakes and you can get rid of the majority of them easily.
    Be prepared to be sweeping any surface with a slight negative charge - the stuff goes everywhere! It'll stick to vertical surfaces.
  5. adirondak5
    adirondak5 Wood Hoarder Extraordinaire
    Long Island NY
  6. trev333
    Coolum Beach,Australia
    Yeh, white toxic snow.... sticks to everything...;)
    the trimmer seems to cut it clean enough without chips... whatever speed it goes?..
  7. thecableguy
    Thanks for all the tips guys! I'll post my results!
  8. otterhound
    otterhound Poster Extraordinaire
    Manheim Pa.
    Can it be cut wet in some way ?
    That should help eliminate static and help keep the dust down . May even help prevent melting .
  9. thecableguy
    I cut the part tonight and I didn't have any melting. I managed to keep the shavings under control by holding the vacuum hose near the bit while it was cutting.
