Routing a finished body?
Discussion in 'Tele Home Depot' started by yeoldeinn, Apr 14, 2014.
  1. yeoldeinn
    yeoldeinn Tele-Meister
    Hello,
    I need to open out an existing pickup cavity in a body that's finished, will a router take chips out or leave it intact? Should I heavily score the finish before routing?
    Is a faster speed best best for this task?
    Thanks
  2. netgear69
    netgear69 Tele-Afflicted
    england
    never tried that but scoring makes sense if you are doing it free hand without a template i wish you the best of luck
  3. Tatercaster
    Tatercaster Friend of Leo's
    Rock Hill, SC
    I would think a very sharp bit at high speed makes the most sense. I've routed a finished body, but used an end mill.
  4. ItchyFingers
    ItchyFingers Tele-Afflicted
    Ottawa Ontario Canada
  5. Tom Pettingill
    Tom Pettingill Tele-Holic
    California
    A template is definitely recommended. To add, use masking tape to protect the body and then use double sided tape to fasten the template.
  6. metecem
    metecem Friend of Leo's
    Dierberg, Rheinsberg, Germany
    Take Tom's advice. Cover the back with masking tape and use double sided tape to fix a template onto it. If you can, get a larger piece of plywood where you can duplicate the template first so you can as well clamp the template to avoid any possible slipping.
    Use a new bit, a sharp one. And no, never go slow with the routing (as to router speed)! Don't ask me how I know that! :)
  7. Joe Sailor
    Joe Sailor Tele-Afflicted
    Longmont, CO
    I had great luck with a drum sander attachment on a drill for turning a humbucker to a P90 route. Believe the body was a soft basswood. Didn't have to take off much. It left the paint intact. Slow, but I did it freehand.
    They are about an inch long, er, 2.5 cm.
  8. Tatercaster
    Rock Hill, SC
    So, if we were using a milling machine instead of a router, how fast should it run? 2,500 rpm is top speed. 4 flute mills of various sizes.
  9. trev333
    Coolum Beach,Australia
    I just made a pattern and routed straight into the finish.. to mount some dog ear P90's into a Whibley squire...:twisted:
    it was a clean cut without any noticeable chipouts....:cool:
  10. Tatercaster
    Rock Hill, SC
    I like it.
  11. dsutton24
    dsutton24 Doctor of Teleocity Ad Free Member
    Illinois
    I've routed finished bodies a bunch of times, and have never had trouble with chipping. I'm careful to use a sharp bit, and make light, nibbling cuts.
  12. Ronkirn
    Ronkirn Doctor of Teleocity
    Jacksonville, FL
    take a paper towel, using spray glue glue it to the bottom of the router... don't worry about scoring... not necessary..
    Ron Kirn
  13. trev333
    interesting to note,,,, there was NO PU rout under the PG for a neck PU on this Whibley body... virgin white....:eek:...
    a great Esquire/Cab mod body if you don't want a guard...:)
    which felt especially heinous to rout through...:twisted:..
    oh.. and the big head strat type neck on these is one of my fav necks to play.. a full C which feels great in the palm...:cool:
  14. CapnCrunch
    CapnCrunch Friend of Leo's
    Washington, USA
    Genius! Never thought of that before.
