Router plunge / cut depth for ½" BB ply?
Discussion in 'Shock Brother's DIY Amps' started by King Fan, Jul 25, 2021.
  1. King Fan
    Salt Lake City
    I hope this is my best place to ask cabinet woodworking questions? For a baffle, I got some nice (B/BB) ½" baltic birch plywood from Woodcraft, and a ¼" double-flute plunge bit from Freud, and I have a circle cut attachment on my variable-speed, 1.5 HP router.
    But searching the web and YouTube, I see all sorts of suggestions for depth-of-cut, from 2mm up to 8 mm -- someone was even cutting ½" in a single pass. I realize it depends on RPM and cut rate, but I'm kinda wondering what experienced builders here suggest.
  2. Frodebro
    Seattle
    I generally don't go much deeper than about 1/4" per pass, regardless of the size of the bit.
    oldunc and King Fan like this.
  3. tele_savales
    tele_savales Tele-Afflicted Platinum Supporter
    Brooklyn, Joey!
    I've used my super cheap amazon-bought WEN dremel-type tool w a straight cutter and a $15 circle cutter jig and did a 12" hole all the way thru in one pass in 13mm ply. It was really dangerous.
  4. tele_savales
    Brooklyn, Joey!
    It worked tho! 1C44B024-3860-4B6F-AC91-B793E407512F.jpeg 4E9389F9-10F0-4FC8-9757-41549E879D07.jpeg
    jimbo735 likes this.
  5. oldunc
    oldunc Tele-Afflicted
    California
    Yeah, 1/4" would probably be a good standard, though certainly not written in stone. I might start with a very shallow first pass just to assure a clean cut of the top veneer. If you're planning to cut out a circle you need to secure both parts of the piece carefully so that when your circle comes free the offcut doesn't get caught in the cutter; that can get kind of messy and dangerous.
    Jackadder and King Fan like this.
  6. King Fan
    Salt Lake City
    <lolol> So that's a "what *not* to do, but it worked" answer? :):):)
    WalthamMoosical likes this.
  7. Frodebro
    Seattle
    I guess it really depends on whether the sight of your own blood makes you queasy or not...
  8. King Fan
    Salt Lake City
    I was gonna clamp the square stock, but hadn't thought about the "donut hole" piece.
  9. Frodebro
    Seattle
    The "donut hole" is where the pivot point is, and what the router is anchored to. You really don't want it to move around...
  10. tele_savales
    Brooklyn, Joey!
    Pretty much. I think once I started my options seems to be burning the motor out on the tool or snapping the bit, and I had an extra bit. So I forced it.
  11. tele_savales
    Brooklyn, Joey!
    I didn’t find the waste circle to be an issue once it cut loose, but if you’re worried you could flush screw it down into your work table.
    Old Deaf Roadie and King Fan like this.
  12. andrewRneumann
    andrewRneumann Tele-Holic
    Cincinnati, OH, USA
    I’ve always cut the speaker hole with a jig saw. I’ve free handed and used a circle jig, both with excellent results. And I never feared for my life or worried about slipping and messing something up.
    I never thought of using a router. Is there an advantage to it?
    Kevin Wolfe and D'tar like this.
  13. tele_savales
    Brooklyn, Joey!
    10x faster and cleaner once you build or buy a jig and get your technique down.
    oldunc and andrewRneumann like this.
  14. Lowerleftcoast
    california
    I have tried several methods ending with good results.
    My go to method now: I have a pattern made of MDF and use a router bit with a bearing. It is like cutting a body. I trace the circle on the baffle. Cut near the tracing with a jig saw. Clamp the pattern to the baffle and use the router to make the finished hole. Resting the bearing against the pattern. I find it to be quicker and less likely to screw up. The router bits are not used as much so they stay sharp longer. Areas of the baffle more prone to tear out can have several passes with the router to alleviate that problem.
    I usually cut the baffle rectangular dimensions after cutting the speaker hole.
    Nickfl, King Fan and andrewRneumann like this.
  15. telepraise
    telepraise Tele-Afflicted
    Tampa Bay
    I only use solid carbide spiral bits for that kind of work. Even then, I only go 1/8" at a pass. There's no hurry.
    King Fan likes this.
  16. King Fan
    Salt Lake City
    Good point. I guess each pass might add a few seconds of work. Oh, plus the seconds it takes to advance the plunge stop. Who knows, it might add up to several minutes. :)
  17. oldunc
    California
    There are trammel point circle cutters that extend out to about 8" and hole saws at least to 6", but they really require a drill press. Of course if you're going to do several cuts, you can make a simple pattern and use pattern bits or, if you want to vary sizes a bit, template guides and straight bits.
  18. BigDaddy23
    BigDaddy23 Tele-Holic
    As others have mentioned above, it's easier to do it in a couple of passes with the trammel jig (I go in 3mm / 1/8" increments with my router as that's what the depth stop adjuster indexes at). That way when you get to the last bit that frees the 'circle' you can sneak up on it and control it nicely. I do this after I have fitted the grill cloth edge strips and turn the baffle board so it is face down. This way, the furthest the 'circle' and router can ever drop when it frees up is the thickness of the edge strips....not that you should let it drop...anticipate and control it! You will generally have a little bit to clean up by hand with a file where it separates.
  19. King Fan
    Salt Lake City
    I was going to cut the circle with my handheld jigsaw on a homemade 'radial sled' circle jig before I found so many YouTubes of cutting a circle with a router (including many on DIY jigs). And *then* I realized my Makita's edge guide converts to a circle jig. Well, duh. But I've never routed plywood before, and that's when YouTube and woodworking sites got confusing. You all helped. And now I know the waste chunk needs stabilization, too.
    Sure, I can overthink things. :) But overthinking is like whiskey. As Mark Twain said, "Too much is just enough."
    oldunc likes this.
  20. oldunc
    California
    This is especially true of power tools and especiallier of routers- if something goes wrong it usually happens WAY too fast for you to react; you need to think out your entire process before you turn anything on.
    King Fan and Frodebro like this.
