Rounding bindings
Discussion in 'Finely Finished' started by mialsa, Apr 21, 2021.
  1. mialsa
    mialsa NEW MEMBER!
    Finland
    Hello,
    Have you done any rounding for the bindings and how? I mean I have how a body with bubinga top, then 1 mm white and 1.5 mm black binding. It has now sharp edges. The back has around 4 mm rounding and for the top I would like to have a bit matching smoothing. 1 mm and 2 mm router bits are quite rare, but have you done something for the bindings and how?
    What for instance 2-3 mm rounding would look like? Have you any examples?
    br.
    Mika
  2. Wyatt
    Wyatt Tele-Afflicted
    It doesn't take much, it's only plastic. A notched binding scrapper or maybe a concave exacto blade or round it off with sandpaper. You can do three bevels then round it.
    This would have to be done before finishing.
  3. Freeman Keller
    I bind guitars with both wood and plastic - most of the time the wood is 0.080 thick and the plastic usually around 0..060. I often have purfling lines inside the binding. I simply run around the binding using a box cutter blade as a scraper to round off the edge. I prefer a scraper to sanding because sand frequently carries dark or light dust into contrasting colors - scraping keeps the binding and purfling cleaner
