Rotary Impedance Switch Schematic for 4, 8, 16 ohm
Discussion in 'Amp Central Station' started by Gazza74, Sep 20, 2021.
  1. Gazza74
    Gazza74 TDPRI Member
    United Kingdom
    I noticed several others have been struggling with this design, so thought I would share what I've found. Hammond makes a rotary impedance switch to support their line of OTs. However, I think the schematic supports other OTs just cross reference your OT wire color to the Hammond color scheme. I also attached the technical document supporting this mod. Hope this helps.
    trancedental likes this.
  2. muscmp
    muscmp Friend of Leo's
    california
    i have one on my 5e3 build but rarely ever use it. thanks for the diagram and prompting me to use it more often.
    play music!
  3. schmee
    Attach the negative feedback wire to the normal impedance tap on the switch.
  4. Gazza74
    United Kingdom
    @schmee thanks for that advice on the NFB lead. Question, my amp build is a 5F2-A and I have a 22k resistor for the NFB. I believe this is the spec for a 4 ohm speaker which I have. Should I connect the NFB lead to the #1 lug along with the green 4ohm lead from the OT?
  5. 2L man
    2L man Tele-Holic
    Finland
    Yes!
  6. schmee
    Yes, usually you connect to the "standard" output, even if you dont use it. It's not super critical though, just changes the NFB a little is my understanding.
  7. Gazza74
    United Kingdom
    Thanks! @schmee I am going to install 3 jacks for switching to different speaker cabs with different ohms. Do I need to jumper the black common wire across all three jacks ground lugs?
  8. schmee
    Yeah that'll work. They often ground through the chassis.
  9. Gazza74
    United Kingdom
    Thanks!
  10. doug
    doug TDPRI Member Silver Supporter
    Boston,MA USA
    What switch are you using?
