Roland cube 10-gx or the Blackstar ID Core 10 v2
Discussion in 'Modeling Amps, Plugins and Apps' started by Karlo, Apr 7, 2020.
  1. Karlo
    Karlo NEW MEMBER!
    Croatia
    Im looking for a bedroom amp and I was wondering which is better for a maybe guns n roses and jimi Hendrix
  2. TX_Slinger
    TX_Slinger TDPRI Member
    Houston, TX
    Had the 40w version of that Blackstar. Should do both with no problem but make sure you use a PC to build your patches. The panel on the amp is really just for tweaking, not for tone building.
  3. Fretting out
    Fretting out Friend of Leo's
    Land of Mary
    I have an ID core 10 , not sure which version but it’s probably 6 years old, if the cube has good EQ, for example more than one knob get that.
    I just can’t get the ID to have the tone I want especially with the single “tone” knob, my boss katana mini sounds better and is just about as loud with a 3 band eq.
    As far as cubes I’ve heard good things but never tried one I wouldn’t recommend a small blackstar to anyone
    (I’ve never plugged my computer into my blackstar and wouldn’t know where to start)
  4. TX_Slinger
    Houston, TX
    You open up a world of functionality by connecting it and i would say its pointless to own one if you dont plan on using the PC interface. The Vox VT and VT+ series are the only modeling amps i know of that you can build great tones on without a PC connected. It just gives you a graphic interface that looks like your effects are laid out on the floor. Couldn't be simpler[​IMG]
    Fretting out likes this.
  5. jageya
    jageya Tele-Holic
    usa
    i had an id core 40 which is the largest of the id core and it was cool..i never should have sold that to mess with.
