We're going to need photos.
324 is B+ to the OTs. The plates receive 288. I’ll look into the other stuff when I canHey that's a cool project.
IMO, 324V on the plates is plenty to give you sufficient volume. Definitely more than a 1/4W!
Back to your original problem. The signal should not cut out when one and only one tap of the OT secondary is grounded. This indicates a problem if you cannot ground the secondary. If you disconnect the grounds and measure resistance from each binding post to ground, you should get essentially 1.9kΩ. (This assumes NFB is connected. With no NFB, you should read OL--open circuit.) Can you verify that please?
324 is B+ to the OTs. The plates receive 288. I’ll look into the other stuff when I can![]()
I haven’t decided if I’m going “shabby chic” or if I want to finish it. I soldered the Jack/pot plates in with a propane torch, which ruined the authentically distressed look in those spots. Oh well. It sounds good and is pretty quiet for homemade high-gain. Surprising, given some long wire runs that were necessary because one of my goals was to not hack up the chassis or cabinet. Oh, and all the iron is inside the original AK cans. That was another goal.We're going to need photos.
Yes, current is stupid-high. I measured over 100ma at about half volume. I’ll get to the voltages soon…Something is odd here. You are using the Hammond 125DSE OTs... each has a primary DCR of 126.5Ω or thereabouts. If you are dropping 36V over the OT primary (324 minus 288), that is 285mA of current per tube, which is insanely high. I think it is time for us to see voltages (to chassis) on all pins (heater pins measured in AC), plus send us the voltages (to chassis) at B+1,2,3. If you can put them all into a nice table format, that would be awesome.
Line AC: 121
Filament AC: 6.1
PT AC: 263
B+: 322
B+1: 280
B+2: 278
B+3: 266
6v6 plates: 283
6v6 screens: 279
12ax7 plates: 183
No red-plating, OTs are cool as cukes.
Removing NFBs results only in hum. I did notice that the shielding doesn’t seem to be necessary.Ok we need to see the other pin voltages too, pins 1 through 8 around the clock on both power tubes and 1 through 9 on the preamp tubes. If you’ve got some resistors mounted to unused pins, don’t worry about it—we’ll figure it out. Just report each pin.
I’ve given you a couple instructions to completely disconnect NFB at the binding posts, but you haven’t responded to that idea. Has that been tried?
Here are the complete voltages:
V1 - 12ax7
1: 183
2: 0.1 mv
3: 16
4/5: 16
6: 183
7: 0.3 mv
8: 16
9: 16
V2 - 6V6
1: 279 (tied to screen by 470 ohm)
2: 16
3: 283
4: 279
5: 20 mv
6: 3 mv (nc)
7: 16
8: 16
V3 - 6V6
1: 279 (to screen - 470)
2: 16
3: 283
4: 279
5: 80 mv
6: 3 mv (nc)
7: 16
8: 16
Yeah, I wondered about that…
Do you want more close-up pics?
I’ve wondered about the coating. All ground points have continuity, though. Could it still be an issue even with my meter showing continuity?Side note:
For safety reasons, you should remove the plastic wire tie from the safety ground. This bolt shouldn't have anything on it except safety ground. Make sure that the cake pan coating has been ground away so that your bolts/star washers get the best contact possible. I'm starting to wonder if your cake pan is causing other grounding issues.
Safety ground saftied. Now that I fixed my NFB wiring error, all of those points read 0v.
I ground away the coating at all ground points. The amp is much louder now with a predictable sweep through the volume control—BUT, I’m still getting low voltage:-/
B+ remains ~325v. HV a/c is only ~260. That said, plate current is normal…
I think it’s functionally ok. Thanks for all the help, guys. I’ll post some pics when it’s loaded into the cabinet.
