RobRob Bassman Micro mods validation
Discussion in 'Shock Brother's DIY Amps' started by Hyakuya, May 17, 2021.
  1. Hyakuya
    Hyakuya TDPRI Member
    Brighton, UK
    Hi guys
    I'm in the planning stages of a @robrob Bassman Micro LTP EF80 and thinking of adding a few mods. I've butchered the layout Rob provides with my plan and wanted to ask if some more experienced eyes can take a look to make sure I've interpreted the mods correctly.
    I've got a load of 6N2P tubes which I'd like to use but the filament wiring is different so I've added this switch.
    3-Way Feedback switch with a 50k pot to adjust the heavy value.
    Elevated 6.3v CT
    Bright / Normal switch and Gain Boost mod using a 50k pot.
    RAW control mod.
    Here's the whole layout with my changes....
    Thanks in advance... :)
  2. zeppelinofled69
    zeppelinofled69 Tele-Meister
    Buffalo, NY
    Your filament switch design will not work, as the 12AY7 side puts a dead short on the heater winding when it's in the 6N2P setting. You have the two filament legs tied to the same switch lug, so they will always be connected.
    JohnnyCrash likes this.
  3. zeppelinofled69
    Buffalo, NY
    I would wait for someone else to confirm this as I just drew it up, but I think this will do what you are looking for... however you will need a 3pdt switch instead of that DPDT.
    EDIT: Another thing to consider is all of the pinouts I have seen for the 6N2P have pin 9 tied to ground. I am not sure if this is needed, but you should definitely keep it in mind. I have added an option with a 4pdt switch that would cover the ground scenario.
  4. dougsta
    dougsta Tele-Meister
    Edinburgh, Scotland
    I've used a DTDP for the filament switch and didn't bother with the screen ground option.
    zeppelinofled69 likes this.
  5. Lowerleftcoast
    california
  6. zeppelinofled69
    Buffalo, NY
    Ah, see. I knew someone could do it better. I always have a hard time getting my switching as simple as it could be, but there ya go... a few different ways.
    Lowerleftcoast likes this.
  7. Lowerleftcoast
    california
    I am right there with you zepp, now I am waiting for someone to do it better.:)
  8. Hyakuya
    Brighton, UK
    working out how to wire that switch was driving me round the bend and the short was spotted soon after I posted.... Ended up with this.
    I'm thinking about adding adjustable bias to the EF80s as well now....
  9. robrob
    United States
    The NFB needs to connected to the speaker tip, not ground (G).
    Hyakuya and King Fan like this.
