Dudes,
I'd like to build a RR BlackVibe but want to get the power transformer right.
Here is RR's recommended PT but this is for 120v.
What should I use for Japan/100v?
Thanks
I recommend the use of a Princeton Reverb chassis and Classictone 40-18027 Princeton Reverb power transformer. The 40-18027 supports 120v and 240v mains and has two high voltage windings. We'll use the 275-0-275v 100ma red-white high voltage leads which are perfect for the Blackvibe Micro. The entire amp uses only 24ma at idle. The power transformer has a 6.3v center tap so an artificial center tap is not needed. We connect the 6.3v center tap to the hot side of the power tube cathode resistor to elevate its ground reference to reduce heater hum. If you need a stand-up transformer the Classictone 40-18085 is perfect.
Thanks
