Dylanmarleyyoung
Hello everyone I’m new to the forum and would like to know if you guys could help? I have a build in progress of rob’s deluxe micro and would like to use a 6bm8 as the power tube simply because I have a couple. I am using the power transformer from an old rheme roberts 1725 reel to reel and the out put transformer (5k to 8ohms I believe)as well. The power transformer out puts 230-0-230 and gives me a b+ of 310 after diode rectification. It also has 2 6.3 outputs without center taps and one of the two 6.3s has thicker wire. I already have all the components like caps, resistors and wire and would like to make a single ended amp with my parts but not to sure were to start in adding the 6bm8 tube any advice would be appreciated.
