Rob’s JCM800 vs 18 watt lite Iib
Discussion in 'Shock Brother's DIY Amps' started by Mongo Park, Jan 19, 2020.
  1. Mongo Park
    Mongo Park Tele-Holic
    Winnipeg
    I have not really ventured far outside the Fender comfort zone. And thought it was time to take a walk on the wild side.
    Rob’s JCM 800 Micro, the 20 watts or so, looked like a good place to make something different but good sounding. Before I committed to hardware I wanted to ask how this compares to the 18watt lite or is it apples and oranges here. If so I will back Rob and go that way.
    any experience would be appreciated
    Cheers Ron.
  2. dan40
    dan40 Tele-Afflicted
    Richmond Va
    Rob offers two version of the 800. One is a one watt micro version using a 12au7 and the other is a 15-20 watt 6v6 version. The preamps in both are a cascaded gain stage/cathode follower style just like a Marshall JCM 800.
    The 18 watt lite has a slightly different preamp architecture and gets most of it's overdrive from the el84 output section. They have to be pretty loud to sound their best in my opinion. The cascaded preamp in the 800 will allow for OD tones at lower volume levels thanks to the master volume.
    robrob and sds1 like this.
  3. Mongo Park
    Winnipeg
    Thanks Rob’s sounds like the one for me.
    robrob and dan40 like this.
  4. jtcnj
    jtcnj Tele-Holic
    Brick, N.J. USA
    I'll be watching!!
    i have the 1W version on deck when I can get the time for it.
    robrob likes this.
  5. Mongo Park
    Winnipeg
    Looking forward to it. I am just lining up the Iron . Got a request in with Matt at Musical Power Supply, he makes great Transformers. I will collect together the other many small parts in the mean time, and considering the speaker.
    Cheers Ron.
  6. tubedood
    tubedood Tele-Meister
    Orlando
    I would like to try that 1 watt JCM also when time allows.
    Will be watching to see how others builds go and sound!
  7. jtcnj
    jtcnj Tele-Holic
    Brick, N.J. USA
    I used his
    http://rover.ebay.com/rover/1/711-5...0001&campid=5338148343&icep_item=153333319317
    I believe this would also be suitable at 6.6k primary for 6v6, but check with him.
    The Allen TO-26 lists plate to plate impedance at 7k.
    The JJ sheet lists 6v6 Push-Pull Ra-a (I think this is the spec) at 10k.
    The Tung-Sol sheet I have lists push pull plate to plate as 10k@ 250v, 8k @285v.
    The impedance appears to drop as plate voltage increases; so the 393v on Rob's schematic probably pushes the predicted number down, where 6.6k is fine. Again, the Allen is 7k.
    I believe being in the ballpark is sufficient.
    I went with 8.5k primary for my last 6v6 build - 6G2- using the Hammond EDB1760E
    Both work fine and sound great; I couldn't tell you if the different primary impedance makes any noticeable difference while playing.
    This has been my experience, as I'm no expert.
  8. printer2
    The Lite just has a volume and tone control, the 18 Watt TMB has a regular tone stack.
    dan40 likes this.
