Rhythm guitar overdrive/distortion
Discussion in 'The Stomp Box' started by Broke&Gearless, Sep 6, 2015.
  1. Broke&Gearless
    Broke&Gearless TDPRI Member
    Singapore
    Guitarteach, i disagree. The vox ac4 is a sweet little amp, vox chime and sparkle in a portable package. Definitely loud enough for now and a long time to come, and its definitely a class amp.
    But for the more important matter...valvestate, how much is the j&h in sing dollars? I was looking at catalinbread dls, 250 from SV guitars...if the j&h is cheaper i will be emailing guitar77 soon. Thanks for the information! I didnt know that they were still open for appointments, only that they closed down.
  2. aunchaki
    aunchaki Friend of Leo's
    Central New York
    The King of Tone/Prince of Tone are modded BluesBreaker v1 boxes. There are plenty of good ones available now for cheap.
    Here's a thread from earlier this year: http://www.tdpri.com/forum/stomp-box/553032-bluesbreaker-brawl-4-bbv1s-enter-1-leaves.html
    The BlackBox from Snouse came out very-highly regarded in that thread.
  3. waparker4
    Philadelphia, PA
    Boss OD-3.
  4. valvestate
    valvestate Tele-Afflicted
    Land of the Merlion
    You definitely need to stretch your budget if you are only looking at $250.. i know that VS J&H v3 is almost $300 if im not mistaken. You better off checking Carousell... i saw some add there selling a Son Of Hyde and Route 808. Try to see if you can "offer" more reasonable price for both..
    i rarely buy new pedals here... always 2nd hand.
  5. Broke&Gearless
    Singapore
    Well, i went back and watched some reviews of the J&H. Turns out, the OD side is a tubescreamer thing, so that ruined it. Now i have the OCD and catalinbread DLS again.
    OCD: Cheaper with "loose" bottom end, drive is pretty great.
    DLS: stunning, but worried it will not work well with Vox. More expensive.
  6. Tle4
    Tle4 Tele-Afflicted
    Warrington, Pa. USA
    I didn't find the OCD loose at all unless you want it to be. There is a LP/HP switch on the OCD which gives more or less distortion and low end. I found that if it was too loose, I would just adjust the treble to tighten it up. I found that on the OCD if you turn up the gain, you need to adjust the treble also
    No experience with the DLS. Isn't that one supposed to be a Marshall in a box pedal? Those pedals tend to sound best through a really clean amp where with an OD pedal,you can use it to overdrive the front end of the amp if you want. The OCD is an overdrive but has enough gain to get into distortion territory
  7. TheletterJ
    TheletterJ Tele-Afflicted
    Rochester, NY
    The OCD is the one OD I have that never seems to stay off my board for long and is truly a "keeper." It can really do anything from clean boost to full shred and anything in between and does it well. Can't go wrong with the OCD.
  8. semi-hollowbody
    semi-hollowbody TDPRI Member
    Metro Detroit, MI
    this isn't as fast as switching on a pedal...or as accurate...imho:D
    try a boost in front of your dirt pedal
    mi audio boost n buff...this will take most crunchy rhythm tones straight into lead territory:D
  9. cousinpaul
    cousinpaul Friend of Leo's
    Nashville TN
    I'd start with a Red Llama set to low gain for the Stones/tweed rhythm tones and add the TS for lead work. It's a proven combination into a Vox. Read up on Tom Petty and Mike Campbell's use of the Way Huge Camel Toe; a RL/TS double pedal. There are many RL clones available for under $100 USD.
    If you're wanting a drive pedal to knock down an always on TS for rhythm work, I think you're looking at the problem backwards. Get your rhythm tone first, then add the TS for leads. Hope this helps.
  10. TheletterJ
    Rochester, NY
    Which is exactly why the Jekyll and Hyde is so brilliant!
  11. valvestate
    Land of the Merlion
    Yup.. this AGAIN. All guitarist need a VS and especiallya TS808/ 9 on their board... if you play live, Tubescreamer.pedals just makes everything sound so beautiful.
  12. losrogers
    losrogers Tele-Meister
    Tucson
    OP, Gain Changer will give the rhythm tones you seek. Feels great through a Vox circuit. You'll be smiling, even with all knobs at noon.
    And for your future expansion, stack it with Direct Drive compact. You won't miss the TS with your Vox.
    Barber dirt is really good. Start with a Gain Changer.
  13. Broke&Gearless
    Singapore
    As previously explained, i like a clean lead tone and distorted/driven rhythn tone. It is unconventional but i guess its just a personal thing.
    The left side on a jekyll and hyde, as i found out, is a TS kind of thing, which rules it out for me as i want something Not a TS sound. But thanks for the suggestion.
    The red llama...sounds interesting. Ill go check it out soon...thanks for the suggestion.
  14. DaveKS
    DaveKS Friend of Leo's
    KS
    You sound like perfect candidate for Mad Professor Underdrive or HBE Detox EQ. You basically set up amp for lead tone, and then when you kick pedal on in chokes your input signal back a hair and allows you to re-EQ all in one pedal click. What your describing is exactly what their made to do. A EQD Tone Job or other EQ could probably probably get you in same ballpark.
    Many people say just roll your vol knob of but I don't like treble roll off you usually get doing that, and as you've noticed, EQ also needs some reshaping.
  15. Broke&Gearless
    Singapore
    Well as it is i have set my sights on a barber compact direct drive after finding one second hand. Thank you for all your suggestions, especially losrogers who suggested barber pedals.
  16. mattyboy
    mattyboy Tele-Meister
    ohio
    Hey if the deal on the Barber doesn't work out, then check out the Cmatmods Signadrive. It's a great TS pedal that does rhythm & leads very well.
    I also use the AC4-12" & works great with the signa.
  17. losrogers
    Tucson
    DDC is my newest pedal, about 3-4 weeks now, and I really like using it as a clean lead boost or very mild OD with a Vox AC10.
    I now own three Barber pedals which bumped all my favorite dirt pedals:
    Including Boss, Fulltone, Ibanez, and Maxon.
  18. t.e.l.e.
    t.e.l.e. Tele-Meister
    OCD or if it's too focused the good old BD-2 if you want more grit. Don't forget to roll your volume back for rhythm.
