Reverse controls
Discussion in 'Telecaster Discussion Forum' started by oceanblue, Aug 12, 2019.
  1. Preacher
    Preacher Friend of Leo's
    Big D
    It is a great mod,
    However not all bodies are routed with a control cavity that will allow the depth of the switch to work. I had to break the router out on a MIM body to make the change. And the leads are not always long enough on the pots to turn the plate around.
    Just so someone doesn't think it is pulling a pair of screws and turning the plate around, it could be that easy... but then it might not be.
    NicDo likes this.
  2. DrPepper
    DrPepper Friend of Leo's Ad Free Member
    Con: Now your hand will hit the volume control, been there, done that, switched back and learned to control my picking hand and how to do volume swells with the stock positioning.
  3. NicDo
    NicDo TDPRI Member
    NH
    I did this to my 08 MiM and love it.
    They should comes this way in my opinion. I usually use a volume pedal, but still like the vol knob closer to me.
    I did it mainly because it can be slow to move the switch out of the bridge position quickly since it's nearly pinned against the vol knob in the standard layout, and I think it looks better. I've never had any issue hitting the controls by mistake on a Tele. Flipping over my CV 50s Tele when I get around to it.
    On the MiM it was tight. Probably should have routed out the cavity a little in depth, but I don't have a router.
    Certainly needed longer wiring, and the tight fit meant covering the bottoms and sides of the pots and switch with electrical tape was must to keep it all from shorting out.
