I want to wire my Tele with a 4 way switch and reverse control plate. I'd like to have the 4 way selection bridge, bridge-neck parallel, bridge-neck series, neck. Does anyone know of a wiring diagram for this configuration?
Ok, so I want the bridge pickup connection closest to the tone pot when I swap it to the other side? That's the part that always screws me up.
Common issue caused by the increased throw angle of the four way.
How did you cut it? I tried with mine, and the thing cracked in half.I had to cut a little off the (lead edge) bottom skirt of my tip on the 4W I put in my Squier CV Thinline.
This is funny to me, I installed a 6 way on two identical strats, with the same exact issue, took me awhile to find it was a mechanical thing not a goof in my wiring.I figured it out. The control plate slot didn't have enough opening for the 1st position on the switch to engage.
