Reverse Baja pickup wiring?
Robkay
Leek Staffs UK
Just wired a tele plate for standard 4 way Baja pickup wiring but now the chap wants the plate reversing with the switch nearest the bottom of the guitar with the tone control/up down phase switch and the volume in the normal position......can anyone guide me to a circuit for this?
Billy3
Charleston,Sc
So you want to reverse control plate correct? From bridge to nut, switch, tone, volume. Regular 4 way ( b/b-n/b-n series/n)with out of phase. It can be done with a push pull. Need more specific details. We will get you there.
Robkay
Leek Staffs UK
This is what I have at the moment........so need switch nearest bottom of guitar then tone with phase switch and then vol towards neck...if that makes sense.
jvin248
Lions & Tigers oh Mi !
That's the way I do it on my Teles, reversed control plate with the switch to the rear.
I use the standard 4-way diagram but I swap the neck/bridge hot wires and after soldering I rotate the control plate.
That gives me Neck/parallel/Bridge/humbucker in the sequence shown on my Esquire-H with the reverse control plate here ... That way I can slam from clean 'neck' single coil to heavy humbucker drive. If I want quack or twang I just back up one notch from the ends.
