Reverb tank
Discussion in 'Amp Central Station' started by Clive Hugh, Oct 22, 2018.
  1. Clive Hugh
    Clive Hugh Tele-Afflicted
    Western Australia
    The reverb on my amp died, to see if it was the tank or electrics I took the tank out and plugged it into another of the same amp, nada so it seems that the tank is dead, going to try the good tank and I see that the rca were plugged into the amp the opposite of the other amp. The amp is not marked + or - so does it matter which one is plugged in where because the tank is marked input and output.
    If it does matter how can I determine which is which. Thanks
  2. BobbyZ
    BobbyZ Doctor of Teleocity
    Snellman MN
    What amp ?
    On a vintage Fender it won't work plugged in wrong, haven't hurt anything yet plugging one in wrong. I am more careful now.
  3. Mike Simpson
    Gilbert, AZ (PHX)
    Make sure the reverb cables are not the problem.
  4. derekirving
    derekirving TDPRI Member
    santa rosa
    Few things to try (sounds like you've tried a few of these)
    1. Change reverb tube
    2. Put reverb tank in diff amp (if doesn't work one way plugged in, reverse plugs and try again) -- it does make a difference on how the pan is plugged in, there's an input and output
    3. Check rca cables in amp (that's not working)
    4. Investigate the reverb pan, specificaly the thin wires around the transducers (see photo)
    5. Worse case, purchase new reverb pan, they run between $20-$50
    ### I found this photo from someone else on TPDRI
    jondanger likes this.
  5. Clive Hugh
    Western Australia
    Thanks guys, I will swap the tank that is working to make sure it is either the tank or tubes, I was just concerned about the plugs but BobbyZ sorted that.
  6. wanderin kind
    wanderin kind Tele-Meister
    Olympia WA
    hi z coil open
  7. Clive Hugh
    Western Australia
    Swapped the tank and the amp worked just fine, ordered a new one from tubesandmore.com, the post and exchange rate blew it out to Au$82 but still cheaper than local.
