Reverb in the Effects Loop?
Discussion in 'Amp Central Station' started by TommyTunaHand, Jan 21, 2020.
  1. TommyTunaHand
    TommyTunaHand TDPRI Member
    Seattle
    New to the forum, so let me know if this thread is in the wrong zone.
    Anyway, I recently got a Fender Tonemaster head, which doesn't have reverb. I really don't like the way reverb pedals interact before or after Distortion/fuzz on my pedal board. To me it sounds muddy or "wet" (I've experimented with a few reverb pedals with similar results). I put some velcro on top of the amp and run a Topanga reverb through the effects Loop. Kind of a pain with all the chords, but I like the sound. I'm curious if anyone else does this, or if this is an improper, and possibly damaging solution. Thoughts?
  2. Nick Fanis
    Athens-GREECE
    It's fine.
    That's why the amp has an effect loop in the first place.
    If you like the sound by all means use it.
    Frodebro and TommyTunaHand like this.
  3. Guitarteach
    Echo, delay, reverb.. For anything time based, the fx loop is the place to try them first.
  4. TommyTunaHand
    Seattle
    Thanks for the replies. Most people I've talked to have no problem running reverb on their pedal board, but there's something unpalatable about it. Probably a discussion for a different thread, but I am curious if anyone else notices negative reverb/drive interaction.
  5. Guitarteach
    they are probably running into very clean amps.
    TommyTunaHand likes this.
  6. tamer_of_banthas
    tamer_of_banthas Tele-Meister
    The Void
    i usually just run it straight into the front end of the amp. and it's digital. does not sound bad, but i think most people just let their own personal tastes dictate that part of the signal chain and whether or not to drop it in the loop
  7. Les H
    Les H Tele-Holic
    Kansas
    In the loop for me.
    If the preamp of the amp is distorting at all reverb in front never sounds good good to me into the front of an amp. I think it sounds ok if the amp is clean but still not my preferred method.
    Typically the onboard reverb in an amp happens between the preamp and power amp. The same place the effects loop sits so to me it only makes sense to run reverb in the loop, at least if you are wanting it to sound more natural.
    I prefer delay in the loop as well.
  8. TommyTunaHand
    Seattle
  9. Crobbins
    Crobbins Friend of Leo's Ad Free Member
    Meiners Oaks CA.
    I run an Eventide H9 through the fx loop in my Friedman small box. Sounds great.
