Reverb Feedback....
Discussion in 'Glowing Bottle Tube Amp Forum' started by Joe M, Jan 20, 2020.
  1. Joe M
    Joe M Super Moderator Staff Member
    Michigan
    Admin Post
    Just brought home a Fender Fudge Brownie PRRI. Way different sounding than the "regular" model with the ceramic speaker. Problem is, if I turn the reverb up past 2.5 or so, huge feedback roars out of the amp, even with nothing plugged in. I've had a ton of Fender amps, both vintage and reissue, and have never had this problem. Before I lug the amp back to the store (50 mile round trip) I'd like to ask the collective wisdom of the group here. My first guess is that it's a pre-amp tube. Which one should I try swapping first? If that doesn't work, any other guesses as to what the problem may be?
    Thanks for any help.
  2. Wally
    V2 should be a 12AT7 and is the reverb driver. V3, a 12AX7, has one triode as a gain stage and one triode that is the reverb return.
  3. Joe M
    Michigan
    Admin Post
    Thanks, Wally, I'll give those a swap later today.
  4. Wally
    If the tube change doesn’t stop the squeal, try pressing the top of the reverb tank. If the squealing stops, one could go into installing some vibration insulation. But....with a new amp this is troubling to have this problem, imho. If it is used, then one can do what one wants eliminate the feedback. Foam rubber strips, tank bag....
  5. Joe M
    Michigan
    Admin Post
    Ok, squealing gone, but with a kind of weird solution.....changed out V2, squeal still there; changed out V3, squeal still not gone; moved the amp from my work place back to it's stand, tried it one more time before taking it back and, no more squeal. The only other variable I can see was unplugging and plugging the footswitch, which I can't believe could have been the problem. Anyway, I really don't care, it's working the way it should, so I'm a happy camper.
    Thanks again, Wally, for pointing me to the right tubes.
    Wally likes this.
  6. Wally
    You may have had a slightly oxidized connection there...or there may be a bad connection in the footswitch cable that corrected itself during the process.
  7. Joe M
    Michigan
    Admin Post
    Wait, are you saying that the footswitch connection could have been the problem all along????
    Snfoilhat likes this.
  8. corliss1
    Lansing, MI
    Yup - there is signal on the footswitch, which is why it's shielded.
    Mexitele Blues, Snfoilhat and Wally like this.
  9. Joe M
    Michigan
    Admin Post
    Color me stupid, if that's the reason.....:oops:
  10. bumnote
    bumnote Tele-Meister Ad Free Member
    Northern Virginia
    I have that exact same PRRI...I liked that speaker even better after a break-in.
    Anyway...my foot-switch crapped out close to a year out. First the trem was never entirely off....then that button stopped functioning. I could probably fix it...but haven't tried. At some point I'll replace it will a good foot-switch, but honestly don't need to anytime soon.
    Other than that I love the amp.
  11. aerhed
    aerhed Friend of Leo's
    Boulder, WY
    If you really really want to solve that I have a wireless footswitch for you.
  12. Wally
    nah...that does not establish stupidity. It is merely one of many reasons why a squeal could happen. Checking the simple stuff first eliminates possibilities.
  13. Joe M
    Michigan
    Admin Post
    I've always subscribed to that theory myself; look for the simple things first. Never crossed my mind that the switch could be the problem, I thought that a bad tube would be the simplest fix. Anyway, as I said, doesn't matter, it works now. I'm not even gonna put the original tubes back in, let sleeping dogs lie....
    Thanks again for the help guys....
    Wally and corliss1 like this.
  14. Switchy
    Switchy Tele-Holic
    Arizona
    Do not most people use a pedal reverb instead of the built in reverb? Just curious.
    My little crappy Frontman has reverb, but I don't use it at all. I use my Oceans 11.
  15. corliss1
    Lansing, MI
    The whole point of Fender amps is the onboard reverb :D :D
    Wally likes this.
  16. Joe M
    Michigan
    Admin Post
    ^^^^This
