Schlumpfmeister
Ok, back after a week of absence waiting for parts. I since replaced all electrolytics. For the two filter caps in paper left and right I took the inside out and stuffed 2x10u each in, so it even looks original.
Problem is the can, because now it buzzes. I was very careful to preserving the complete wiring. Turns out the can housing serves as star point for ground, as 3 of 4 outer legs are being utilized to connecting all kinds of black wire, then one of them connecting to the amp chassis with a very short wire. I kept this all in place which was a nightmare to work on, partially turning the amp upside down and soldering from the outside for the connections deep into the far end of the housing, then mounting it mechanically, then connecting the rest of the leads that are in reach from the top. And then it buzzed. So I suppose I either have a ground connection somewhere or a bad soldering joint, so back to square one and all over once more.
On a side note, the mechanical restauration is also pretty messy, I have it re-tolexed as someone had it covered with black leatherette. It took me 4 hours and all sorts of chemicals to eliminate the old (elastic, sticky) glue, just to learn from the amp builder doing the tolexing that he will spend another (paid for) 2 hours!
I know about the issue, rectifier tubes have a maximum filter capacity specified to limit startup current. I had that with a Deluxe Reverb that had gotten recapped using 100u filter caps. It displayed a lighting beam at startup!
So when I do an old amp it gets every electrolytic replaced. The cathode bypass caps really don't hurt anything if they blow but I've had so many issues go away with a fresh set.
No, R12 R-B, it uses an integrated silicon diode network, the part is really tiny!Oh if that amp uses a 5y3 rectifier tube,...
