Restoring 1972 Twin Reverb
Discussion in 'Amp Tech Center' started by Keyrose, Sep 15, 2020 at 12:23 PM.
  1. Keyrose
    Keyrose TDPRI Member
    US
    Thanks for all your help guys! I'm feeling confident that I can do this as a project. Would anyone know a good electrolytic capacitor kit?
  2. Ten Over
    Ten Over Tele-Holic
    Central California
    Here are a couple of options. The kits don't seem to notice that the vibrato uses a 5uF bypass capacitor.
  3. Jake Nelson
    Jake Nelson Tele-Meister
    Alexandria, MN
    Built a 6L6 Blackvibe after playing a Twin Reverb and everything rattles at anything over low volume... this thing is LOUD!!
    Anyway carry on. Twins are my favorite.
  4. BobbyZ
    BobbyZ Doctor of Teleocity
    Snellman MN
    Can't remember how many times I've forgotten about that darn 5uf cap and just put in a 25uf-25volt.
    Other than old Ampegs where I might order a kit from Fliptops I just order caps from someone like ACS. F&Ts for the filters and 100uf-100 volt bias and Sprague for the 25uf-25volt caps, about 50 bucks to do a Twin Reverb. Add a buck or two for the trim pot to add to the balance pot, and you'll need a resister for that too.
    Personally I'd probably go with a service first and try it before taking out the mod. I'd probably go ahead and yank the mods anyway but it's fun to try stuff.
    First amp I soldered on was a silverface TR, honestly wouldn't recommend one of those for a beginner. First thing you'll do is burn a bunch of spots in that Easy-Melt insulation on the wires and it'll look like hell. Don't ask me how I know. . . .
    But if you're going to do people here will help.
    Two ways to change a cathode bypass cap.
    Right way. Desolder the eyelets and solder in new caps.
    Easy way. Clip leads right next to old POS white Mallory, bend eyelet on old lead, solder new caps there. That "hack" method cuts your time in there with hot things way down. So you melt little or none of the wax on the board and less chance of burning spots all over the wires. The electrons won't care, but other techs will call you a hack. I already use a soldering gun and really don't care. :)
    Yeah I do it the easy way on silverfaces. Blackfaces are just so much nicer to work on so I do those the right way.
    I do pull the filter cap board out for a complete desolder and cleaning on either though. That's simple enough.
    Oh in case no one told you.
    Twins are loud and heavy.
    (I've got two)
  5. Keyrose
    US
    So the value for the tremolo bypass doesn't make a difference? Which one is the balance pot and why should I add a trim pot? Thank you for the advice on the caps. Some areas do look rather hard to get to without burning some wire. And yes, I am aware the twins are very loud, that's why I got a quad ;):D
    BobbyZ likes this.
  6. BobbyZ
    Snellman MN
    The blackfaces used a 25uf caps across the whole board, like I said i just forget to order the 5ufs and haven't had any trouble.
    Balance pot is the one buy the power transformer you use a screwdriver to adjust. As originally wired they raise the bias on two tubes and lower it on the other two. You had to swap a resister to change the overall bias, kind of a pain.
    At some point they put a hum balance pot on the back of the chassis, in the heater filament string. Seems to be late 100 watters that got that, right before they went to the 135 watt ULs.
  7. Keyrose
    US
    Oh ok, I was under the impression that the pot was a bias pot. There is a small blue resistor that is soldered from the back of the pot to the middle lug, would that be the one that I change to a trim pot?
  8. BobbyZ
    Snellman MN
  9. BobbyZ
    Snellman MN
  10. BobbyZ
    Snellman MN
    What I do is measure the bias, voltage with no tubes, say it's -40 and tubes aren't redplating or whatever. When you get done and turn the pot you should get the same voltage at some point, maybe now it goes from -35 to -45. Then you're in the ballpark.
    For matched tubes take the voltmeter and set the balance pot so you've got about the same voltage coming out both sides. Hard to hit the exact center point but something within reason.
    If you're actually trying to set bias for mismatched tubes it's more fiddly. It doesn't have to be exact anyway.
    Keyrose likes this.
  11. Keyrose
    US
    Thanks a bunch! This is all very helpful. I'll be sure to add this. Would I need any special instruments to check the bias or can I do it with a multimeter?
    Edit: Just read your last post
  12. Ten Over
    Ten Over Tele-Holic
    Central California
    The 5uF bypass cap on the tremolo evens out the intensity across the speed range. A 25uF cap causes the intensity to increase as the speed is decreased.
    If you are ever inclined to delete the bias balance in favor of a bias level, here are a couple of ideas:
  13. avspecialist
    avspecialist Tele-Meister
    avon,ct
    To answer a question “ does anybody know of a good capacitor kit”. I like F&T for the electrolytics. Mojotone has small parts kits they sell also.
    Keyrose likes this.
  14. Keyrose
    US
    I ordered a kit with F&T and Sprague caps
  15. avspecialist
    avon,ct
    Good to hear. I hope all goes well reinstalling. I would do 1 part at a time noting the orientation of especially the electrolytics. How are your soldering skills?
  16. Keyrose
    US
    Yes, I'll definitely take precaution with the orientation. The amp hasn't been turned on in a while but I'll go through the process of draining the filter caps in case there is some juice left in them. My soldering skills are pretty good. I have done mods on my guitar and pedals before.
