Replacing Tele Pick Guard when Bridge P/U is Mounted to Body
Discussion in 'Fender Custom Shop Tele Forum' started by Emgeesea, Feb 8, 2021.
  1. peteycaster
    peteycaster Tele-Holic Silver Supporter
    Also try lowering the pickup as far as it will go and bring it back up atetr the pg is in place.
  2. loudboy
    loudboy Tele-Meister
    Sedona, Arizona
    The adjustment screws are hidden by the pickguard.
  3. hmemerson
    hmemerson Tele-Meister Vendor Member
    Huntington Station, NY
    The neck pickup has either springs or rubber sleeves around the screws, although there is sometimes a piece of dense foam rubber under the pickup bottom. They push the pickup up and the screws work against that pressure, so......
    If you were to push down on the pickup, it SHOULD move, right?
    If the springs or rubber are too strong they could be replaced with softer ones. This would make it much easier to swap out pickguards.
    .....and no: Removing the neck will not appreciably change your set up provided that any shims (if there were any used) are put back exactly where they were located.
    It ain't rocket science. Leo had a method to his madness.
    Regards,
    Howard Emerson
  4. Telecasterless
    Telecasterless Friend of Leo's
    los angeles
    C'mon dude, unnecessary.
    Copy/paste. That's it. It works.
  5. Esetter1
    Esetter1 TDPRI Member Silver Supporter
    Loosen the neck just a hair to free the guard material under the overhang. The neck pickup is usually mounted over a spongey material or through springs so it can be pushed down a bit to allow the PG to come off.
    Just make sure the screws through the neck cavity aren't binding when you tighten them back down.
  6. hamerfan
    hamerfan Tele-Meister
    Germany, Bavaria
    That's why Leo had only 21 frets on his necks.
