When opening up the case of my MXR carbon copy the stomp switch fell apart. I replaced it but now the pedal does not pass signal. Well, actually you still can hear the "pop" being delayed when either the battery or input is plugged in with the pedal turned ON. There is no signal with switch in both positions otherwise.
I have soldering experience working on tube amps but little on pedals and PCB's. I wonder if I damaged the board or something? The original switch was a major pain to get out and required a bit of yanking and heat. Any ideas?
