Replacing selector switch with pot
Discussion in 'Tele-Technical' started by Mongo Park, Apr 9, 2017.
  1. Mongo Park
    Mongo Park Tele-Holic
    Winnipeg
    I have a tele which I moded to put in a pot to to replace the selector switch. I bought a pot from fle bay that was described as the pot to be used for this mod. Now that it is in it does not give a smooth continuous sweep from one Pu to the other. It has a center marker at which both pu's are equal. If I turn it either way from this position it instantly switches to one pu or the other, depending which way I turn the knob. So it really still works like a switch. What I wanted was something that gives more of a smooth mix from one pu to the other, which would be what I thought a pot would do.
    Could somebody show me what sort of pot would give a smooth transition from one pu to the other. Cheers Ron
  2. dobrojoe
    dobrojoe Tele-Meister
    England
    If you can find the schematic for a Rickenbacker 'blend' control, you will see how it works. Now, the problem as I see it is that a volume control has an audio (Log) taper. I don't know of a potentiometer that has Log going in both directions so it is possible that you are using a linear taper pot. That's why you are getting a sudden change of volume and not the 'blend' you are expecting.
    Another way to get this effect is to use a five way selector switch which gives N, N+1/2B, N+B, 1/2N+B, B. This is easy to do. If you replace the volume and tone pots with push-pulls, you have have series and out of phase versions of all these tones.
  3. Peter Rabbit
    Peter Rabbit Tele-Holic
    Toronto, Ontario, Canada
    Or, get an M/N taper blend pot:
    Sarde likes this.
  4. Mongo Park
    Winnipeg
  5. Mongo Park
    Winnipeg
    Thank you both, this gives me somthing to work towards, you must be a linear taper. Very kind of of both of you to share your knoweldge.
    Cheers Ron
  6. Peter Rabbit
    You're welcome. That's why we're all here.
  7. JC22
    JC22 TDPRI Member
    Sacramento
    I like!
