Endless Mike
How-d,
So the title gives the general idea. I've removed the original grille covering material, which was twenty-three years old and falling apart. Just pushing your fingers into it would rip it.
So now I have to get the new material on. I know how to handle everything but one small part, which is actually a big part. Everything else is easy with a staple gun. So in the attached image, you'll see a horizontal gap along the upper area underneath the Rivera name plate, and the grille cloth was attached there by some sort of glue/adhesive. How in the heck do I hold the grille cloth in place while the glue dries? I don't think the piping was used to do this, as the piping along the top came right out, without much resistance. It certainly wasn't glued into place.
I'm hoping someone here has had experience with this sort of thing, and can tell me how to accomplish this. I have wire of the right diameter that could be pushed into place to hold the grille cloth in place until the glue dries, but then the wire won't likely come back out once the glue has dried. Not without taking some or all of what I've just installed with it.
The first photo shows the same model amp as mine, which has the controls on top, like a Fender Bassman or Blues Deluxe/Deville. So no, it's not just a cabinet. Notice the piping under the Rivera name plate, right along the top of the upper most horizontal edge of the grille cloth. The second photo shows my actual grille, sans cloth, and the gap where the grille cloth is glued in and the piping runs.
Thank you for your help, as I really need it.
