Replacing electric heat thermostats.
Discussion in 'Bad Dog Cafe' started by HotRodSteve, May 23, 2020.
  1. HotRodSteve
    HotRodSteve Friend of Leo's
    The Hudson Valley
    Hopefully I won't get electrocuted or burn the house down but I'll be replacing three electric heat thermostats when they arrive from Amazon. Double-pole Honeywells, should be fun. Wish me luck.
    String Tree likes this.
  2. dented
    dented Doctor of Teleocity Gold Supporter
    I-10 East onramp
    What an electrifying experience......
    0511-0810-3119-1735_Cartoon_of_a_Man_Holding_a_Faulty_Electical_Cord_clipart_image.jpg.png
    rangercaster and HotRodSteve like this.
  3. Treehouse
    Treehouse Tele-Meister
    The Woods
    Does your home have one of those circuit breaker box thingamabobers?
  4. RodeoTex
    RodeoTex Doctor of Teleocity
    Nueces Strip
    Those are probable going to be 24volt, but still...
  5. schmee
    They are just low voltage. Are you putting in digitals? I thought I wanted a digital on my last house, but turns out I didnt really like it that much. Programmed to come on at a time sounds handy but sometimes, you just dont need it on, or you want it NOW! Went back to old school 'stats and am happy.
  6. stratoman1
    stratoman1 Friend of Leo's
    Virginia Beach, Va
    I was going to replace mine til i counted 18 wires on the back of it
    Bassman8 likes this.
  7. String Tree
    String Tree Doctor of Teleocity Ad Free Member
    Up North
    Just make sure the Breaker is turned off before you start.
    LINE is the power In from the Breaker, LOAD is the Power Out to the Heater.
    Stay safe, stay warm.
    HotRodSteve likes this.
  8. Milspec
    Milspec Friend of Leo's Silver Supporter
    Nebraska
    I agree, all that custom setting sales talk really didn't impress me after installation either. I miss the old school t-stat
  9. String Tree
    Up North
    2-Pole is usually the domain of 250VAC Resitive wall and ceiling heaters.
    24v is for Furnaces be they Gas or electric.
  10. dogmeat
    dogmeat Tele-Afflicted
    Alaska
    they are 24 VAC.... thats AC. they can give you a tingle under the right circumstances but I don't think they are much of a danger. usually there is a switch on the boiler/furnace that turns off power. if they use batteries (in the T-stats) there will come a day when the temp in the house is really hot, but the boiler will still be running. thats from the battery being dead. long ways off though... couple years maybe more
  11. stormsedge
    stormsedge Tele-Afflicted Gold Supporter
    Tennessee, USA
    They are easy to install. Follow the instructions. Open the breakers for the hvac system before starting work. Check the leads on the old thermostat for stray voltage with your ohm meter to ensure you have the power off. I've lost count of how many I've changed out.
  12. stxrus
    stxrus Friend of Leo's
    St. Croix, USVI
    What is heating and thermostats?
    Expiring minds want to know
    Treehouse likes this.
  13. Glen W
    Glen W Tele-Afflicted
    CT
    Electric baseboard heat thermostats are switching line voltage - 240VAC - not 24V like for a furnace or boiler. Hire a pro! If not, locate and shut off the (2-pole) breaker. Then use a tester to ensure you got the correct circuit. You should have a separate circuit for each room/area’s thermostat.
  14. HotRodSteve
    The Hudson Valley
    It sure does and the previous owner actually labeled the breakers correctly, which is nice. But I will test for voltage after flipping the breaker. Don't want to get zapped with 240v.
    stormsedge and Treehouse like this.
  15. HotRodSteve
    The Hudson Valley
    Each room's electric heat has it's own thermostat and breaker. And I will test for sure.
    Glen W and stormsedge like this.
  16. DonM
    DonM Friend of Leo's Silver Supporter
    Henderson,NV/SLC,UT
    Easy. YouTube is your friend.
  17. Treehouse
    The Woods
    @DonM YouTube is owned by Google. They are only pretending to be your friend.
    spellcaster likes this.
  18. DonM
    Henderson,NV/SLC,UT
    I don’t care who owns them, they’ve saved my ass several times. Just about everything’s owned by Google or Amazon. That train has left the station a long time ago.
  19. Treehouse
    The Woods
    Cool
  20. jumpnblues
    jumpnblues Friend of Leo's
    Midwest
    We have electric base board heat. Even our certified electrician can't get it to work. However, we just use one base board heater for the entire upstairs in the winter. We like to sleep in a cool room so we don't use the base board heater in our master bedroom. It's a small room and a small house. We heat the upstairs with the baseboard heater in the kitchen. The kitchen and living room are open to each other. We don't heat the guest bedroom but it has a functional base board heater. I just wish we could get the upstairs base board heater in the living room in working order. All the rooms on the lower level are heated but we don't use them since we have a wood burning stove in the downstairs living area. Anyway, if we could get the upstairs living room heated we'd be completely in business.
