Replacing AC Socket on Vox AC4C1
Discussion in 'Amp Tech Center' started by tre_byrd, May 6, 2021.
  1. tre_byrd
    tre_byrd TDPRI Member
    SC
    Anyone know the value of the capacitor that is underneath the heat shrink on the ground wire (blk) that connects the back of the AC socket to the On/Off switch. My was destroyed and I can't see the values on the capacitor. I do not see a way to measure capacitance on my multimeter.
    Is this capacitor necessary?
    I've attached a couple photos of the existing conditions, any info would be appreciated
  2. gusfinley
    gusfinley Tele-Afflicted
    SLC, UT
    Its not a ceramic capacitor its a thermal fuse (Gas Discharge Tube?). It shuts off when the amp is pulling too much current and resets itself after it gets happy again.
    This is labelled SG1 SURGE GUARD on the schematic. I don't see any values or hint for replacement other than that.
    You have an mains fuse and a Heater Fuse, so you could just remove it.
  3. Jon Snell
    Jon Snell Tele-Holic
    Jurassic Coast. Great Britian.
    Peegoo likes this.
  4. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    I had an amp come in with the inrush current limiter popped (the side was blown out) and I replaced it with one rated for 25 Ohms/3A.
    Jon Snell likes this.
  5. tre_byrd
    SC
    thank you all!!! The product in the ebay link looks pretty close to what used to be in the amp so I'll go ahead and replace just for piece of mind.
