Relicing a bridge plate and finding copper beneath chrome
Discussion in 'Tele Home Depot' started by Jackroadkill, Jul 19, 2019.
  1. Jackroadkill
    Jackroadkill TDPRI Member
    Wales, UK
    Hi all,
    I'm hoping you might have some knowledge of relicing and be able to answer a question for me.
    I'm planning to use ferric chloride to weather a Fender Tele bridge plate, and decided to to a practise run on a cheapo Squier plate that I had lying around. The ferric chloride stripped the chrome off really well, but underneath there appears to be a layer of copper (presumably part of the electro-plating process).
    The big question is, will I find this on the Fender plate too?
    Any help or advice will be gratefully received.
    Thanks,
    JRK
  2. strat a various
    Is that copper or brass?
    nojazzhere likes this.
  3. Zepfan
    Zepfan Poster Extraordinaire
    Horn Lake, MS
    Usually find copper or zinc plating under chrome.
    Chunkocaster and Jackroadkill like this.
  4. Jackroadkill
    Wales, UK
    Definitely copper. Might have to soak the bridge in vinegar or something too.
  5. strat a various
    Mmm, that sounds good.
    Jackroadkill likes this.
  6. Zepfan
    Horn Lake, MS
    Watch out for build up of toxic fumes.
  7. schmee
    schmee Poster Extraordinaire
    That indicates a good chrome job, so I would guess you will.
  8. StrangerNY
    StrangerNY Friend of Leo's Gold Supporter
    Long Island, New York
    A bit chewy, though.
    - D
  9. theprofessor
    theprofessor Friend of Leo's
    Chattanooga, TN
    Yes, that's been my experience with Fender stuff: copper beneath chrome plating. I ran into that on a Fender Pure Vintage Telecaster neck pickup cover.
  10. Jackroadkill
    Wales, UK
    Thanks for the tips, lads.
  11. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
  12. Jackroadkill
    Wales, UK
    What did you do about the copper?
  13. bender66
    on my bike
    Are you relicing or trying to remove the plating?
    Relicing should just weather the chrome a bit. How long did you leave it? Submerged or fumes?
    Chunkocaster likes this.
  14. Jackroadkill
    Wales, UK
    Just trying to age it without letting the copper show through too much. I had another go and found that submersion for a bit less time seems to work ok.
  15. Chunkocaster
    In space with Ziggy
    As referenced above you want to be using the fumes rather than submersing the parts in acid if you are shooting for natural aging. Submersing it will give the lost at sea for 50 years and barnacle damaged look. Chrome is a little harder to achieve natural looking results than nickel.
    Jackroadkill and bender66 like this.
  16. bender66
    on my bike
    Yes. Good description. Elevate your item in a container with a lid. That'll knock back the finish subtly.
    I'd use a good respirator too without fail, even outside. Those fumes will take your breath away for good.
  17. Chunkocaster
    In space with Ziggy
    I watched a video of it years ago by a guy called Billy Penn? before attempting it myself. Its on YouTube and shows what to do in detail. Worked great for me. I think chrome took several 20 min sweats and then rinse before you think its done, nickel took a few 10 min sweat sessions then rinse when you think it's not quite done. The nickel turned out perfect, lightly aged grey looking with no spots. The chrome reacts weird and turns blue, yellow looking but settles down to have a slight rust tint to it. The fumes will strip the chrome off if you leave it too long.
    Here's the Pennaliser to fill you in on the fine details.:)
  18. Paul G.
    Paul G. Friend of Leo's
    Rhode Island
    Chrome on steel usually goes over copper plating. It gives added corrosion resistance, fill in any imperfections and helps with adhesion. The copper is polished, then chrome plated.
    Sometimes chrome goes over nickel.
  19. Ronkirn
    Jacksonville, FL
    the reason for the copper is. . . Chrome does not adhere to raw steel... but it "sticks" superbly to copper .. Problem.. copper doesn't "like" steel much either... but it loves Nickel.... thus the "triple plated" process... Nickel loves steel.. so it's a applied first, then the copper, which will stick to nickel... and finally a copper film is applied because it sticks to nickel and Chrome sticks to it...
    Now. careful. Muriatic acid will dissolve the Chrome at light steel... try it .. the chrome will disappear faster than the light can be carried to your eyes... (not really) but fast non the less.... Copper is much less reactive,, so it will hang in there for considerably longer... same with Nickel...
    So just be careful with whatever you're doing... sometimes the info on You Tube, isn't all that it could bre..
    fk
    monkeybanana likes this.
  20. theprofessor
    Chattanooga, TN
    I just left it alone. I relic'd the pickup cover with 600-grit sandpaper, and the copper shows through just a bit on one edge of the pickup cover.
