Relic-real rust?
Discussion in 'Fender Custom Shop Tele Forum' started by frenchy51, Mar 9, 2015.
  1. frenchy51
    frenchy51 Tele-Meister
    Nor-Cal USA
    I'm thinking of pulling the trigger on a CS '61 Relic. Could someone tell me if the "rust" (bridge, tuners, etc.) is real rust or is it some type of coating? Can it be toned down or removed? I like the relic look to the body but I hate rust....Thanks in advance
  2. Plumber
    Plumber Tele-Holic
    london
    on the ones ive seen and own its real rust - not something that bothers me at all though
  3. telex76
    telex76 Doctor of Teleocity Silver Supporter
    Fort Worth,Tx.
    I always clean and oil my hardware. Don't want it to keep rusting.
  4. christhebrit
    christhebrit Tele-Holic
    Kent
    I've got a cs 61 relic and its real rust or an incredibly good faking. It's not my favourite feature, but it would look odd if it was shiny I guess.
  5. 1hoofer
    1hoofer Tele-Meister
    I got the custom shop to put 1950s rust on my 53 relic.
  6. frenchy51
    Nor-Cal USA
    So they have a stock pile of vintage rust-cool....(-;
  7. BradL
    BradL Friend of Leo's Gold Supporter
    Sussex, UK
    It's rust all right and I've had to swap out fused parts in the past which is either moronic or ironic I can't decide which :p Faux aging is one thing but non functioning parts are quite another and while it might be related to the salty air in my part of the world more likely the guitars came from FCS like that.
    In my worst case I ended up having to source new (fake aged) saddles because the ones on the CS Tele weren't coming away from the intonation screws in a month of sundays. Spraying Plus Gas achieved little and I couldn't very well soak them in contact cleaner or whatever without including the entire bridge plate as well.
    After several such episodes I started checking guitars in the shop (before buying) and afterwords removed most of the screws before lubricating them and applying Kurust to the visible parts (preferring black aged to red rust aged).
    More recently I realised how pointless the whole exercise was and stopped buying relics altogether -but that's probably a different story :lol::lol:
  8. Redline Redneck
    Redline Redneck Tele-Meister Silver Supporter
    Alpharetta, GA
    Always keep saddle screws lubricated. If aged, put a drop of Liquid Wrench or some such penetrating agent on each screw. Let sit overnight before loosening and un-assembling. Coat with oil before reassembling.
    Never use WD-40 for this. It is not a lubricant. It's a moisture displacer. Short life.
    The aging process from the Custom Shop make the saddles look great, but the process initiates oxidation at a rapid rate. If it's not halted within a couple months, things get a bit rough. Some bridge screws will seize even though Mike Eldred claimed it would not occur on a CS guitar. I've lived through it and learned.
