That's an old wive's tale. As long as the lacguer is sound and dry and you are applying oil based polyurethane like I stated, it works just fine. Woodworkers apply polyurethane over sanding sealer all the time. What do you think sanding sealer is? Hint: it's lacquer.Poly over nitro is a terrible idea, they are only compatible the other way
Looking better - at least in this light.I laid on another layer with the new brush. This will make the doubtful spectators pleased, as it means heading deep into brush stroke county again!
But fear not, the adept sander will get back to work in a couple of days to get that evened out...
Main goal of this layer was to fill some low spots that appeared after the first sanding session.
I didnt aim for a complete cover here, that is why it looks very blotchy again.
It's not an old wives tale. Lacquer is evaporative and unstable, whereas polyurethane cures chemically and is stable. Sanding sealer *can* be lacquer . . .or it can be a number of other things that are not lacquer.That's an old wive's tale. As long as the lacguer is sound and dry and you are applying oil based polyurethane like I stated, it works just fine. Woodworkers apply polyurethane over sanding sealer all the time. What do you think sanding sealer is? Hint: it's lacquer.
Over the years I have developed a sensitivity to spraying lacquer and try to limit it's use to out of doors. During the winter when I must work indoors, I use wipe-on polyurethane for finishing the gunstocks when doing both refinishing and preservations. Preservations on vintage rifle and shotguns are finish restorations as opposed to completely stripping and refinishing and many of these vintage firearms were originally finished in lacquer. I repair the dents, dings scratches and chips from hunting via lacquer drop fills, removing as little of the original finish and patina as possible and then selectively recoat portions of the stock or the entire stock dependant upon the amount of wear. I apply the polyurethane directly over the lacquer and have no issues whatsoever with adhesion or finished appearance. My clients are literally speechless when I hand them back a vintage firearm that retains it's aged appearance but is free from dings, scratches and other damage.
It's always advisable to sand the lacquer to insure adhesion but in my case, I often blend a polyurethane coated section by feather-edging into an untouched lacquer section along a round-over or contour line. In many cases, I am unable to sand where this transition occurs but have never encountered an appearance or adhesion issue.
Cans are expensive.I like brushing, and I found some people who have managed. I can get really nice colors here for little money of the straight lacquer, but the cans are expensive, so I can finish something like 4 guitars for the price of one if it works out. My investment was low.
I have sprayed nitro from cans before, i have brushed poly, I have done shellac french polish, oil, 2k cans,... I like to experiment
Not in my experience. Here is a Weatherby Vanguard originally finished in urethane. There was a long split running through a knot and one side of the rifle was nicely figured while the side with the split was light colored and very ugly. Based on past work I'd done for the owner, he asked if I could repair the split and improve the stock's appearance making the two sides match better.It's not an old wives tale. Lacquer is evaporative and unstable, whereas polyurethane cures chemically and is stable. Sanding sealer *can* be lacquer . . .or it can be a number of other things that are not lacquer.
You are working with years-old or decades-old lacquer finishes that have mostly gassed off. That is not the boat he is in.
I never said there was a problem with lacquer over poly. It is poly over lacquer that is often a problem. Glad your project worked out though.Not in my experience. Here is a Weatherby Vanguard originally finished in urethane. There was a long split running through a knot and one side of the rifle was nicely figured while the side with the split was light colored and very ugly. Based on past work I'd done for the owner, he asked if I could repair the split and improve the stock's appearance making the two sides match better.
Since I would be graining the stock rather than just staining the figureless wood darker, I chose to leave the original polyurethane finish intact. I did my usual lacquer drop fills on the dings and deep scratches as it is much easier to sand and leaves the surrounding finish intact. I repaired the split with a crazy glue drop fill inside and out and then sprayed the entire side with satin lacquer in preparation to faux grain the wood. That's 1 instance of lacquer applied over polyurethane with no issue.
The wiping stain I use for graining does not stick to polyurethane finishes but spreads smoothly and evenly over a satin lacquer basecoat. I applied the wiping stain over the freshly lacquered side introducing figure lines over the wood.
After the stain dried a few days, I sprayed satin lacquer over the stain. I do this because the wiping polyurethane disturbs the graining when applied, basically dissolving it and wiping it away. It also allows the stain to flow out slightly, making softer edges so as not to appear painted on.
After a few days of drying, I applied multiple coats of oil based Wipe-On Polyurethane to the entire stock to insure a matching gloss all the way around. That's two instances of polyurethane over lacquer on the same project. The results were stunning.
Before (fugliest piece of wood I've ever seen on a Weatherby):
Here's the other side in comparison:
Grained over satin lacquer:
Finished with gloss poly over satin lacquer sealcoat:
No adhesion issues, no lifting of the finish, no problems whatsoever. In my experience, lacquer over poly has never been a problem.
I miss-typed and just corrected my concluding statement. If you read the post, I applied poly as a final finish over the lacquer used to seal off the graining and the repairs.I never said there was a problem with lacquer over poly. It is poly over lacquer that is often a problem. Glad your project worked out though.
It does, but it needs to be done carefully and it needs to be thinned. People paint boats using a technique called 'roll and tip', but they used brushes before rollers were invented and the finish can be very smooth.I wish you well but I see a lot of block sanding in your future.
Lacquer doesn't brush well.
