Redwood Project
Discussion in 'Other T-Types and Partscasters' started by Unionjack515, Nov 9, 2019.
  1. Unionjack515
    Unionjack515 Tele-Holic
    Batavia, IL
    I recently sent two necks (and only one body) to MJT to do a Vince Gill ‘53 project. One neck was quartersawn maple and the other was roasted quartersawn maple. I figured I’d have them both aged in the same way and pick which one I liked better once they sent the parts back to me upon completion. I’ve decided I’m going to keep that Vince Gill project traditional and stick with the unroasted maple on it. That leaves me with an extra neck. What do you need when you’ve got an extra neck? That’s right, an extra body. So I found this cool reclaimed redwood body on Reverb and thought it might be a cool match for the roasted maple neck. I’ve always wanted a B16 Bigsby guitar so I think I’ll use this platform for it. The one-piece bridge is a little scary. I’ve read that old growth redwood can vary pretty widely as a tonewood but tends to be on the brighter side (similar to reclaimed pine I’m guessing). I was also considering a Gilmour Workmate-style pickup set (Esquire with an uncovered neck pickup). This one is turning into a platform to try all kinds of crazy ideas...ha. Pics below of body and a Masterbuilt with the B16.
  2. preactor
    preactor Tele-Holic
    gainesville, ga
    Experimenting is great. Just don't do anything that can't be undone!
    rangercaster and Unionjack515 like this.
  3. Unionjack515
    Batavia, IL
    Agreed! The whole of the Bigsby is “reversible” (albeit with a couple extra holes in the body). Requires a goofy neck angle to clear the bridge pickup height but they make a shim. Like a pine body guitar, I just have to be especially diligent accounting for the softness of the redwood.
    naneek likes this.
  4. preactor
    preactor Tele-Holic
    gainesville, ga
    I have a Sycamore? body (Avatar). On another post there was discussion about putting superglue in the screw holes, letting it DRY and then put the screws afterwards. This was supposed to strengthen the wood. May be something to consider.
    Unionjack515 likes this.
  5. Mudman32
    Mudman32 Tele-Meister
    Upstate NY
    They might make a vibramate too fwiw
  6. ZenGuitarist
    ZenGuitarist Tele-Holic
    Alberta, Canada
    Good luck with your build!
    I have one of the Hot Rod '50s Reclaimed Redwood Telecasters that Fender released as a Limited Edition a few years ago. Mine came with a 4-way switch, compound radius neck, and plays great.
  7. Unionjack515
    Batavia, IL
    What kind of finish? Just curious!
    naneek likes this.
  8. ZenGuitarist
    Alberta, Canada
    According to Fender, the finish on my redwood Tele is a hand-rubbed dark stain oil. The pickguard is 1-ply black bakelite.
    Unionjack515 and naneek like this.
  9. naneek
    naneek Tele-Meister
    PNW
    good luck with your project, looks like it will be a fun one.
    I made a reclaimed pine tele project with wood from a ceiling beam in a 120 year old barn, and it's held up very well over the past 7 years. It's about due for its first setup since assembly and a little electronics work, but I didn't have any real problems with the softness of the wood. I finished it in oil and beeswax with seymour duncan 59 humbuckers and a bakelite pickguard.
    I've always wanted a redwood tele, I'm still keeping an eye out for the right piece of wood.
  10. Unionjack515
    Batavia, IL
    Cavalier pickups ordered today. As usual, Rob was a pleasure to work with. She Wolf for the neck position and Fat Lion for the bridge. Hoping to preemptively tame some highs and fatten it up.
    preactor likes this.
  11. Unionjack515
    Batavia, IL
    Interestingly...I just took a look at my T and soon-to-become-a-T collection and realized for the first time that I have not one Fender in the bunch. Weird. But perfectly ok with me.
  12. Unionjack515
    Batavia, IL
    Seller of the body was nice enough to send some off-cuts along with the body so I can test for finish. Looking forward to trying some different treatments. I also ordered my hardware today and emailed back and forth with Tim at Tru-Arc Bridgeworks. Wow what a resource he is. As some of you may know, the B16 was designed when most players were using a wound G string. So if you’re using a plain G, the bridge needs to be altered or a different bridge needs to be used. Tim offers a custom bridge for the B16 in any of five different metals (aluminum, brass, copper, stainless or titanium), specially radiused to match your fretboard. Most of the rest of the custom options address things that my mind can’t even formulate an opinion on...too much engineering for me. So I’ll do a little chewing on which metal I’d like and go from there! Cool experience!
    Mudman32 likes this.
  13. Unionjack515
    Batavia, IL
    Got the body today. Looks awesome. Tried a few clear-ish options on some of the scrap and I think I’m going to end up going with a fairly natural burst on it. It’s fairly non-descript otherwise. Found these for reference:
  14. Telecentric
    Telecentric Tele-Meister
    Boulder Creek, Ca
    Cool project. I have been toying with the idea of getting a 4" thick redwood slab and making matching Tele and Strat bodies with the same grain pattern.
    I am somewhat skeptical about it being old growth redwood however. Of course it is possible, but just because it is reclaimed redwood doesn't make it old growth. Not that it makes much difference, unless you paid a premium for that provenance. I live in the coastal redwoods, and can tell you that pretty much every tree not currently in a state park was harvested in (roughly) 1907-1910 to rebuild San Francisco. The Santa Cruz Mountains were essentially clear cut. So even if it is 100 year old redwood, it's not necessarily old growth.
  15. Telecentric
    Boulder Creek, Ca
    I have done this, but to be clear I screwed the screws in, then removed them, lightly coated the screws with superglue, screwed them in, then removed them and let dry for a few minutes. This ensures that the threads in the wood were coated yet retained their shape instead of being filled with glue.
  16. Unionjack515
    Batavia, IL
    Good point. I have no clue how old it is, and at this point it doesn’t really matter to be honest. I’m going to have to deal with whatever sonic characteristics it has either way. But I don’t think I paid a premium for age—all in, including shipping from Canada, it was under $200. I did ask the seller how old it is (just for S&G), so we’ll see what he says. Weighs in at 3.75lb, so that’s fun. I’ve had some lighter ash bodies but not by much.
    Telecentric likes this.
  17. Unionjack515
    Batavia, IL
    Buyer says it has actually been reclaimed twice. First time was in the 60s. This was two beams the the seller reclaimed from a home being torn down. And the homeowner had reclaimed them in the 1960s from an old building in (guess where) San Francisco prior to that. Who knows how long they were in that building.
  18. Unionjack515
    Batavia, IL
    Mocked up with this pickguard...might be cool
    Telecentric and radiocaster like this.
  19. Unionjack515
    Batavia, IL
    Ordered a three ply b/w/b celluloid pickguard too. I guess mint should also be an option. Personal preference of course but I’ve always thought maple fretboard guitars worked better with light guards. But I’m generally not a huge fan of white guard Teles.
