Whatizitman
Traded a few non-essentials for a non-working The Twin.
On first inspection, the positive lead on one of the speakers was off, and the amp was on 8ohm. It's wired in series per schematic, for 16ohm. Maybe someone was trying to make it less loud?
I put it back to right before I tested further. It certainly seems to me that the tubes are all original, but can't confirm.
The external fuse (4A) was blown. I put in a 1A (all I had), plugged in through my current limiter, and it powered up. All tubes glowing similarly, no redplating. Off standby the limiter lamp lit up dimly. The amp has a loud buzz off standby, volume down, but otherwise sounds ok in the clean channel. Controls all work. Tried without current limiter, and it held until I switched channels, then blew. With current limiter I was able to use the distortion channel ok. Sounded pretty good, even with the limiter. Plugged in without limiter, died on the distortion channel.
No new smoke or burning smell.
Took chassis out to inspect, and the two 47ohm resistors on the heater supply are badly burned (R303, R303). One looks like it exploded. That even possible? Diode in parallel (anti-parallel, according to the Wiz) with the power LED looks bad, too (D307). The socket for V10 (6L6 on the far right looking at back of amp) has lots of black from something burning. The grid stopper (1.5k?) looks like it could be burnt, but haven't measured. Internal fuse is good.
Interwebz say bad tube, but it looks fine at least visually. The tubes look original to me. Output seemed ok without the limiter.
Caps look newer to me. But I will change them. Just want to get as much pre-planning before ordering parts.
What else should I be looking for? Is the filament supply to blame for blowing fuses, or is there some other culprit? If the 6L6s are ok, could anything else cause this issue with the filament supply? And what possible damage could running it with the open resistors/diode cause? If the main fuse wouldn't blow, that is. Incidentally, this is why I think it's not a bad idea to test with lower amp fuses.
The Twin schem pdf added
