Recone, Repair, or Replace Vintage Jensen 8"
Discussion in 'Amp Tech Center' started by schmerf, Aug 8, 2020.
  1. schmerf
    schmerf TDPRI Member
    In Transit
    I recently got an amp that I love the sound of but one of the 4x8" Jensen speakers has seen better days. It fuzzes out on certain low frequencies.
    The speakers are from 1961 so are old.
    Do you think it is worth reconing or do you have trouble shooting tips for repairing this type of speaker.
    Or do you think the best thing to do would be to replace them?
    If I replace I might be looking to have a new baffle made to keep the original hardware all together. If you have any suggestions on who could make one please let me know.
    Thanks!
    24 track likes this.
  2. Zepfan
    Zepfan Doctor of Teleocity
    Horn Lake, MS
    Re-coning a speaking will cost the same as a new one or possibly more.
    WGS and Weber does re-cone jobs.
  3. schmerf
    In Transit
    Seems like a full recone of all speakers and new speakers would be a similar price.
    unsure whether the Jensens would be better reconed if I like the sound or if something else might sound even better.
  4. Wally
    What amp is this? Note: the IMG is not available to me???
    If the amp is worth the expense, I would want to maintain the originality in whatever way I could. Also, if the amp has not been properly serviced, that needs to be done.
  5. Ricky D.
    Ricky D. Doctor of Teleocity
    Raleigh, North Carolina
    If it was mine I would just recone the bad speaker. Replacing all four would cost four times as much, and it will sound different. If you don't want to change the sound you have now, just fix the bad one.
    Maguchi, mojo filters, Boreas and 2 others like this.
  6. philstrat97
    philstrat97 TDPRI Member
    oregon
    http://jamacspeakers.com/
    These guys repaired a bunch of speakers for me I thought were long gone. Saved me a ton too!! If there is any life left in the old broke speakers, they're worth repairing. It'll take a long time to get new ones that broke in.
    Terrytown likes this.
  7. schmee
    Just replace or recone the one. Depending on what it is, many 8" are cheap used or new.
    MORE INFO
  8. archetype
    archetype Fiend of Leo's
    Williamsville NY
    We can't view your pics. Go to your image gallery and change the permissions on these images to "Everyone."
    schmerf likes this.
  9. schmerf
    In Transit
    Let me know if the images show now.
    It’s an Epiphone Futura.
    It’s newly acquired and at the tech for a once over and three prong cord.
    When reckoning speakers does it make sense to just recone one or should they all be done?
  10. Lowerleftcoast
    Lowerleftcoast Tele-Afflicted
    california
    As a speaker ages the suspension (aka damper or spider) and the surround become more *pliable* for lack of a better word. Becoming more pliable is desired when a speaker is not *broken in* but after it is *broken in* we would like the suspension to remain stable. It does not of course and the day comes when the suspension no longer can do the job. The old speaker will usually show problems with low end and/or loud passages.
    Depending on how you intend to use the amp should guide your decisions.
    If you want it all stock, I would just repair the troublesome speaker(s). This would retain the vintage sound of the amp best.
    If this is your reliable gigging amp, I would replace all of the speakers and pack up the old ones for the future owner.
    Fender Phil likes this.
  11. muscmp
    muscmp Tele-Afflicted
    california
    your tech will tell you whether or not it needs reconing. get that info first and go from there.
    play music!
  12. EsquireOK
    EsquireOK Friend of Leo's
    U.S.A.
    If keeping the amp as close as possible to original is important to you, then have a quality re-cone done.
    If not, then store the originals and install a set of brand new Weber or WGS speakers.
    Myself, I would probably do both. I would recone and/or rebuild the bad speaker as a first step. Even if I ended up installing four brand new speakers instead, I would want to have four working originals in storage. I like having original specs as an option that can be returned to – with all gear, really, but especially old gear.
    Maguchi likes this.
  13. 24 track
    kamloops bc
    I got one of these Apex AA01 a test tone oscillator that will sweep 20 to 20K HZ , sine or square wave tone upto 14 db i tested this unit on my realtime analyser and it was dead accurate.
    I can take the output directly to the speaker and sweep the frequencies to tell me if the speaker is damaged with out pumping a huge amount of signal through it.
    I also use it if I am buying used speakers, so I dont end up with a dud speaker that some how the seller forgot to tell me about, where this differs from a multimeter is that a muktimeter will only show you the speaker resistence, but this will sweep the speakers responce range , a handy tool for sure.
  14. schmee
    Cool, get that reconed to keep it original. There are some cheap on Ebay. http://rover.ebay.com/rover/1/711-5...0001&campid=5338148343&icep_item=224107983509
    Those are light duty though, will you be playing it much? Loud? Weber 8F150's are great, but man, a lot of money when you need 4.
    You could go with new cheap Jensen C8R's. Save the originals with the amp for when you sell.
  15. schmerf
    In Transit
    I like the sound of the speakers in there but do worry that if I just got one fixed up the others would go once the amp was seeing more use. It’s been sitting around for a long time before I got it.
    With everything going on it’s unlikely the amp will be seeing many gigs soon.
    The plan is for it to get quite the recording/rehearsal workout after it’s good to go though. So it will be played a lot and fairly loud.
    I was contemplating having a baffle with new speakers made that I could swap in. Any recommendations on either the right supplies to make One myself or someone to make A custom replacement?
  16. Peegoo
    Peegoo Friend of Leo's
    Panhandle of Wyoming
    A recone kit is about $20 delivered, and anyone that can operate scissors, a bottle of glue, and a solder stick can do a recone. Seriously. Look on yootoob for how to recone a speaker (watch several) and you'll pick up the little tips and stricks necessary to get a good result. It's not wizardry or rocket surgery.
    It really is easy and fun to do.
    And playing an amp through a speaker *you* reconed makes it even more magical and inspiring.
  17. schmerf
    In Transit
    Any recone kit you’d recommend?
  18. Peegoo
    I can't recommend a kit because it depends on the speaker model, the type of suspension, cone shape and depth, type of center cap, the diameter and length of the voice coil, diameter of the spider, etc.
    Contact these folks: www.simplyspeakers.com and see if they have the recone kit you need for your speaker.
    Another company I've used for parts and kits is www.reconingspeakers.com
    benderb9 and schmerf like this.
  19. Wally
    Okay, we can see from the pics that there has been some work done on this amp at some time. Imho, the first order of business is to review that work AND to replace the bias cap, which appears to be original. As for the speaker, one either recones at least one speaker or pull them and replace them all. Box the originals up for preservation.
    Is this a Futura?
  20. kennl
    kennl Tele-Afflicted
    Moon Township, PA
    My recone guy told me that vintage stamped-frame speakers can suffer misalignment if the frame is bent, causing "cone cry"
    Reconing then is only an option after re-alignment is a special fixture that he could not justify purchasing
    If you find a shop that can perform frame alignments, then any speaker can be reconed.
