Recommendations for pickup change for a HS Telecaster
244300
Phoenix — Biltmore
I'm looking for pickup recommendations to blend a humbucker and single-coil on a couple Telecasters I've got.
Especially recommendations related to Fralins.
I mostly play classic rock and I really like to sit in middle position like I do when I use a Les Paul.
dougstrum
blu ridge mtn cabin
I like minihum or firebird for neck and slightly hot bridge like tonerider hot classic or Duncan Donahue.
I spend 3/4 of my time in middle, and shift front or back as needed~
Resojazznblues
Virginia
Imho a Fralin steel pole 42 in the bridge and Fralin paf humbucker with nickel silver cover is a great combo. The Fralin humbucker wound a little hotter. Had a set in a grosh t style I played for years. Best sounding electric I ever played.
244300
Phoenix — Biltmore
I'm digging this suggestion I'd not thought of it before...
https://www.fralinpickups.com/product/pure-paf/
https://www.fralinpickups.com/product/steel-pole-42-telecaster/
So I understand you are suggesting getting the neck Pure PAF wound to 7.8k instead of the stock 7.5k and I see the Steel Pole 42 comes at 6.7k in the bridge.
Is the idea that the hotter neck PAF will "blend" better with the single-coil bridge?
Do you use a 500k pot on the neck and a 250k pot on the bridge?
Any other considerations?
ScribbleSomething
San Antonio
This is outside what you asked, But since you indicated there is more than one — consider getting a humbucker sized gold foil.
I bought the supro version when they were still selling them. Love it.
eallen
Gold Supporter
My automatic I do a lot of is Bill Lawrence Wilde L48 bridge & L90 2.0henry neck with a 5-way Schaller Megaswitch M or 4-way Oakgrisby. 250k pots.
Whatever you do make sure you get a compatable humbucker rather than some high output one that you have to lower to the pickguard to keep from overpowering the single.
There are a couple demos on my YouTube channel but here is one.
244300
Phoenix — Biltmore
Right! That's part of why I'm posting is to find some examples that are known to work.
Resojazznblues
Virginia
Hello. A 500k on the volume. It was a standard Tele scheme 3 way volume tone. The sp42 prefers 500k as does paf, I am sure you know. I don't remember any wiring trickery. Yes the hotter paf blends better with the sp42. The sp42 is like a really nice p90, the paf has that "vintage paf" tone. When you blend them it is like smearing butter on hot pancakes. My grosh had a one piece southern swamp ash body and eastern hard maple neck fingerboard (one piece). That Fralin set really sang in that guitar.
244300
Phoenix — Biltmore
My head was with a Les Paul's controls. 500k on the lone volume, right!
I think there is a very strong possibility I try the Pure PAF at 7.8k and SP42 in a Tele.
Now I do have some other Teles so I'm open for more recommendations...
