Recommendation for saddles
Discussion in 'Tele-Technical' started by TeleFunk Man, May 24, 2019.
  1. TeleFunk Man
    TeleFunk Man Tele-Afflicted
    Gatineau, Québec, CANADA
    Yep, Rutters are great. Have them on my American Standard.
  2. fender4life
    fender4life Friend of Leo's
    los angeles
    I have a bag of various saddles i have tried on every tele i have owned and IMO the fender compensated brass sound most natural. Others i have tried all sound like there are peaks and valleys at various frequencies while the fender comp brass sound balanced among all frequencies. When i get a new tele i always try a bunch of saddles on it but in the end i always end up using the fender comps.
    SPUDCASTER likes this.
  3. gsh1968
    gsh1968 Tele-Holic
    London UK
    I assume a parts reseller. A factory in South Korea started producing a version of the Gotoh/Wilkinson adjustable saddle around a year ago. If they are using their own name instead of Gotoh I'd expect the saddles to be the clones.
  4. Tuxedo Poly
    Tuxedo Poly Tele-Afflicted
    Merseyside UK
    Knock-off parasites.
    Trev Wilkinson should get his legal team on it.
  5. PCollen
    PCollen Friend of Leo's Silver Supporter
    Man of the World
    nojazzhere and TeleFunk Man like this.
  6. TeleFunk Man
    nojazzhere likes this.
  7. boris bubbanov
    New Orleans, LA + in the
    Those will work.
    The brass is about the softest out there and I find those "Wilkys" are actually too compensated.
    Meanwhile you could've had genuine Fender slant compensated saddles thru Darren Riley and they're less money.https://darrenriley.com/store/fender-compensated-telecaster-brass-saddles-0058544049/
    Out of stock at this moment but normally he's got them - ordered batches numerous times, arrived crazy fast from NC.
    And they compensate the "right" amount for quite a few guitars (I treat each guitar like a patient - the prescription they get varies, also depends on the players needs and preferences).
    Thank Goodness you didn't get those Rube Goldberg ones you posted earlier. Those are a hot mess.
  8. boris bubbanov
    I suppose.
    But maybe Trev should disavow the design altogether. Gosh, what awful things those are!
    Maybe Gotoh is quitting making those (under license). Their new design (a ripoff of Marc Rutters) are so many times better IMO.
    I'm very happy with the sets of Rutters I have with the eccentric slots.
  9. tessting1two
    tessting1two Tele-Meister
    Southern California
    I like the Callaham version of those slant saddles mostly because of the smaller hex screws. My favorites of all time were by CJ Tooling. I'm not sure why they sounded better than the others but they did. I sure wish those were still available.
  10. macatt
    macatt Tele-Holic
    silverdale wa
    I really like these:
    Off-set barrels from Philadelphia Luthier.
    I use a Bigsby and other vibrato systems and these saddles have a nice rounded point of contact with the strings; unlike most of the other types which have a sharp point where the strings rest on the saddles.
    There is a lot less chance of the strings 'hanging up' on the saddles with the vibrato action.
    They also control string spacing which is needed with a Bigsby.
    They come in aluminum, steel and brass. And 1/4" or 5/16" diameter.
    https://www.philadelphialuthiertools.com/search.php?search_query=compensated saddles&section=product
    S Mac
    8trackmind likes this.
  11. Matthias
    Matthias Friend of Leo's Gold Supporter
    The Wilkinsons ones are OK as far as they go, but the break angle on the actual saddle is such you can get sitaring at certain saddle heights. Good on a budget.
  12. xgritzx
    xgritzx Tele-Meister
    northern VA
    whatever the bridge on the brad paisley is. its brass saddles but it has bits that move independently so you can intonate better. ive seem the whole bridge used for about $50.
  13. mabley123
    mabley123 Friend of Leo's
    ashland kentucky
  14. TeleFunk Man
    My Wilkinson compensated brass saddles arrived and installed them yesterday, but not set up yet. There was no info on the order of the saddles. I found a YT vid that showed some but not sure if they are the same as these. Can someone with Wilkinson compensated vintage stye saddles take a look the photos here to confirm they are in correct order?
  15. TeleFunk Man
    bblumentritt likes this.
  16. bblumentritt
    bblumentritt Tele-Afflicted Platinum Supporter
    Austin, Texas
  17. Telecentric
    Telecentric Tele-Meister
    Boulder Creek, Ca
    Yeah, that's correct, though you will need to move the center set back some when you intonate, since the G will need to be longer than the B.
  18. TeleFunk Man
    Thanks so much...
  19. santiago53
    santiago53 TDPRI Member
    buenos aires
    +1. Great saddles, I bough a set this month. The sting sits perfectly and the intonation is almost perfect, here is a pic, see the different groove size for each saddle:
    tlp123 and BorderRadio like this.
  20. Telecentric
    Boulder Creek, Ca
