Recommend order delay, reverb , trem
Discussion in 'The Stomp Box' started by texmck54, Apr 12, 2016.
  1. texmck54
    texmck54 Tele-Meister
    Port Dover On. Canada
    What order do you think these three should go on my board. Already have my delay then reverb but I'm getting a trem tommorow so wondering what seems to work best.
  2. Obsessed
    Montana
    Trem > delay > reverb is the traditional order and what I have, but lots of people will have a different opinion based on what they like. Rule of thumb is modulation before ambiance.
    johnhe and Tele1966 like this.
  3. Mike Simpson
    Gilbert, AZ (PHX)
    Delay is on the board... reverb and trem are in the amp...
    waparker4 likes this.
  4. Steve 78
    Steve 78 Friend of Leo's
    Melbourne, Austraila
    If you put the trem at the start, the delay and reverb will wash over the effect and soften it. If you put the trem at the end, it will cut out everything and so sound harder. So it depends on what sound you are after.
    waparker4, Donnie55 and RetroTeleRod like this.
  5. Steve112
    Steve112 Tele-Meister
    Abbotsford Canada
    I`ve run trem>delay>reverb, worked well.
    Obsessed likes this.
  6. Tele1966
    Tele1966 Friend of Leo's
    US
    My current preference is boost > stacked crunch/OD pedals > trem > Corona Chorus > Strymon Timeline > amp (w/reverb)
  7. crossroader
    crossroader Tele-Afflicted
    Endicott, NY
    On both my boards I run them in the "traditional" order: Trem -> Delay -> Reverb (Tuner -> Boost -> OD/Distortion are before those).
    But there are no real "rules" - flip 'em around in any order that works for you.
  8. Tele1966
    US
    Speaking of reverb, I currently have on loan a DigiTech Supernatural Ambient Stereo Reverb Pedal. This pedal is fantastic. I just noticed today the price dropped at Sweetwater. The only issue I have with the pedal is that I've found four or five settings I love, but for gigging it'd be impossible to bend down and dial in each reverb. But for a home studio I think the pedal is worth checking out.
  9. thinkdifferent
    thinkdifferent Tele-Meister
    Good ol' Europe
    It seems that the consensus is more or less Trem > Delay > Reverb.
    May I ask how you would incorporate a Strymon Flint or Mr. Black Deluxe Plus (both Trem and Reverb) into such a setup? Delay before or after the Combopedal?
    Thanks
  10. Obsessed
    Montana
    I have a D+ that I got for my Grab n' Go board. I'm actually not going to have a delay on that board. If you think about it, old school was running straight into an amp that has trem and reverb. My two amps and my future third "basically" don't have either. With that said though, you can turn off the verb, so I would place the delay after the D+, so that trem goes into delay.
  11. Iago
    Iago Friend of Leo's
    Brazil
    I use delay into tremolo for no real reason.
  12. Tele-beeb
    Tele-beeb Friend of Leo's
    The Bluegrass
    I like the tremolo to cut the delay trails... not create more.... so, delay before trem always for me.
    I dig the interplay and bounce-back of trem into reverb... so
    Delay>Trem>Reverb
    waparker4 and bottlenecker like this.
  13. waparker4
    Philadelphia, PA
    I don't think there is a traditional order.
    I would go delay - trem - reverb. In a fender amp which i use the most often, trem and reverb in the amp both would go after delay. When I don't use a Fender amp but the amp has reverb, delay into trem is closest to the fender sound. When the amp doesn't have reverb, reverb pedal can go last. This seems to me like it would be most consistent.
  14. Obsessed
    Montana
    ^^^^^ This is why there is creative music out there and why there are no rules. For someone starting out though, I think conventional wisdom is the best way to begin. Modulation before ambience is the basic "traditional" order for the pedal era. It is true that amp manufacturers have done lots of things and why there are different combination of sounds, but certainly amp manufacturers don't rely on pedal order for their designs. I'm not going to tell anyone which way is best for them, I am trying to give guidelines. However, I'm pretty confident that if you take away the amp built-in effects (and f/x loops), the majority of people are going to end up with trem > delay > reverb anyway. I suppose if you want to be "consistent" with a specific amp's built in effects order that's fine, but for someone just getting into the world of pedals, it seem like confusing advice. Tele-beeb has a great reason why he likes trem after delay and states why. This is also good information for everyone to consider.
    Tele-beeb likes this.
  15. 1300 E Valencia
    Fullerton CA
    Another idea: Ask yourself, "How do they do it in the studio?"
    The "modern" way is, don't print effects at all, record everything dry, and add effects at the mixing stage.
    Old school might still have outboard delay/echo, so it could be tremolo (from the amp), then reverb (amp), then delay. There's all kinds of ways to figure these things.
    Sometimes you're limited to (or inspired by) the limitations of the gear. I'd like to try chorus after delay, but the chorus only has a mono input and stereo outs, so I'd have to run the delay mono, so no ping-pong delays. Chorused delays, or delayed chorus? Which sounds better in stereo? To the lab, Igor!
  16. dezb1
    dezb1 Tele-Holic
    glasgow
    Trem, delay, reverb... or you could go the old fender route delay, reverb, trem... as they got the reverb / trem round the wrong (non standard) way in their older amps.
