WineCaster
Here's what I'm working with. I have a bias pot as well.
I've added a 100k pot to the negative feedback loop. I'm dealing with some rather "high" highs with my setup as it stands.
I agree.Tubes don't break up.
Ok, on a 6V6 amp that I wanted to compress and OD early and sweetly, I'd use cathode bias, cathodyne PI, and a prePI master volume control.
You got a schematic. I can't interpret layouts as easily as I should. I think you are cascading a 12AX7 into another, and out to cathodyne PI. With some bias wobble tremolo.
I agree.
And I understand how one might mis-interpret how I refer to tubes that consistently enable the circuit to break up earlier when they're installed as having "earlier-breakup" character - it may seem like I don't understand your point. My reference to early breakup is a linguistic convenience. And the term is only useful in a relative sense. For example: I know that nominally-new testing samples of '50s black-plate 12AX7 will break up in a particular circuit earlier than '60s short gray-plate 12AX7A every time. This is very predictable character, and I've always found it useful information to become aware of.
- Thom
I neglected to say this at the outset. Winecaster, that's a really beautiful amp. I love the wooden cabinet and the stain color and the way the Vox grill cloth works with it. Very tasteful!
You are welcome to believe what you choose to believe - it won't change the decades of experience I've had with tube swaps that I bring to my recommendations. Maybe try for yourself sometime?What ever terminology we use: As has been pointed out earlier in the thread, the V1 tube in this amp won't "break up" at all, unless you seriously boost the signal from the guitar before the input.
If you find that a certain tube has "earlier break up", put it in V2.
In my previous post I seem to have confused you with the OP.You are welcome to believe what you choose to believe - it won't change the decades of experience I've had with tube swaps that I bring to my recommendations. Maybe try for yourself sometime?
If you're really curious about this phenomenon, here's what I suggest:In my previous post I seem to have confused you with the OP.
But I don't really understand what you mean, try what? Pushing the first triode in a Fender amp into overdrive with a normal guitar signal by swapping tubes?
If I ever obtain those tubes I'd be happy to do that test, maybe even hook up an oscilloscope to the plate of the triode. And most likely, I'd be happy to just play that amp all day longIf you're really curious about this phenomenon, here's what I suggest:
Obtain a '50s long black-plate RCA 12AX7 and a '60s short gray-plate 12AX7A that both test as nominal new, and both with the same approximate transconductance values on the same tester. It helps if you have your own tester, for consistency.
Choose your BF Fender channel, and identify the first input tube for the appropriate channel (V1 for Normal, V2 for the Vibrato channel). Without changing any settings, A-B swap between those two vintage 12AX7 tubes. Play with a dynamic touch, try single-note runs vs. double-stops, and listen carefully to how clean the signal remains.
I chose RCA tubes for this example because they're the most commonly available samples to compare. There are others I can name (and have, previously), but they're often more rare.
Would like to hear your observations, if you feel like reporting back. If you lived nearby, I'd welcome you over for a demonstration. If you're ever in the San Francisco Bay Area, drop me a line.
- Thom
I also firmly believe you can mod the circuit.I don't think any of us are doubting you Opaltone. Some of us believe that we can modify the circuit to achieve the same results.
I'm happy being able to take less than 60 sec to swap a preamp tube.
- T
Just a though. You might try a pair of TS RI 6v6s. I've never actually compared them to JJ 6v6s but the internet says they break up sooner. . . .
Like them in my Reverberockets.
Also if you're running a real efficient speaker (like a Celestion) and playing were you can't get loud, try something else.
