Recommend a Good Boost with a Buffer
Discussion in 'The Stomp Box' started by El Tele Lobo, May 7, 2019.
  1. artdecade
    artdecade Poster Extraordinaire
    Twangsylvania 6-5000
    Ernie Ball MVP.
  2. El Tele Lobo
    El Tele Lobo Friend of Leo's Silver Supporter
    Thanks guys. I ended up going with the Prestige. Should be here middle of next week. When I have more money, I may give one of these others a try.
  3. DavidP
    DavidP Friend of Leo's
    Vancouver BC, Canada
    Yeah, pretty good but has been replaced with the Elevator (https://www.radialeng.com/product/elevator) -- got it in my rig!
  4. wrathfuldeity
    wrathfuldeity Tele-Afflicted
    Turdcaster, WA
    Well you could get on pedal for doing either/or/both (clean boost and klonish fatter OD) VFE Dragon works great for this ;)
    El Tele Lobo likes this.
  5. Danjabellza
    Danjabellza Friend of Leo's
    Pahrump, nv
    The DOD bifet boost is really great, especially for the price. And it has a mini-toggle to switch from buffered to true bypass. Pretty slick.
    Woah! I’m not sure what happened.. but I bought my bifet boost for $30 new a year ago or so. Now they’re $60 used on reverb... weird.
  6. JayDee
    JayDee Tele-Meister
    Missouri
    I knew that the Elevator had replaced it, but it looks like that's been discontinued now. I sure hope that Radial gives it a proper upgrade/replacement. I know I'll be hard to please if my PB1 ever dies. I guess there's always the used market for a replacement.
  7. micadoo
    micadoo TDPRI Member
    Melbourne Australia
    The Klon already has a really great buffer built into it. I have a DIY Klon and have gotten some really great sounds stacking it with a Katana clone I built from the vero at Tagboard effects blog. It's a super simple build and all the parts can be had for under $20. FYI I usually am playing through a 5F2A Tweed Princeton clone with a 10" Weber Sig. Cheers, Micadoo
  8. El Tele Lobo
    A REAL Klon, yes… But my Mosky Golden Horse, unfortunately, is true bypass. So this will be my work around until I can get either a proper Klon or a proper Klon clone with a buffer.
    micadoo likes this.
  9. Treadplatedual
    Treadplatedual Tele-Holic
    Indianapolis, IN
    I think I'm going crazy - I read this thread's title as "Recommend a good toast with butter."
    buffer...but it's not TRUE BYPASS? What is the world coming to? /s
  10. Mark the Moose
    Mark the Moose Tele-Holic
    Erie, CO
    I've built a few boosters: EP, SHO, JHS mini-bomb, Demeter Fat Boost... and a few lower gains I've used as a boost: Timmy, KOT, Klon...
    SHO & mini-bomb were noisy. Demeter Fat Boost is all about lows and mids, I like it for leads but not chords. EP is awesome and has some tone shaping switches. Timmy works well as a clean or dirty boost, I like the EQ section. KOT has the ability to bypass the clipping stages making it a bone clean boost. TC Spark and Spark mini are both lovely as well.
    It all depends on what you want it to do. Girth? Presence? Mids? Treble boost? EP, Timmy or Spark might be best for experimenting with possibilities because they have some EQ shaping abilities.
  11. El Tele Lobo
    I have the Spark. Been pretty happy with it. I think I was just itching to try something. I'll side-by-side it with the Prestige and see which wins out. One of the two will have to be sold for money reasons, so we'll see.
  12. 11 Gauge
    11 Gauge Doctor of Teleocity
    Near BWI Int'l
    I've got a 5E3 replica, which is sort of right in between those two. I've also got an old BF Champ and a few Champ'ish heads that I occasionally use into cabinets.
    Personally, I like to roll off a bit of top end when I use these amps, so I favor either boosts that aren't on the bright side, or possibly might end up using something with tone controls, which IMO isn't actually a boost, but whatever...
    Generally speaking, I think the op amp-based boosts like the Spark are probably going to give you the most mileage, and the Spark probably constitutes the Cadillac of most of them, since it's got tone controls and a voicing toggle. So if you wanted to play around with one knob variations of that, I guess there's the Micro Amp or Boosta Grande, but neither of those are buffered in bypass.
    ...But if you're concerned about signal loading or whatever, assuming maybe you're running a lot of pedals in the chain, I'd personally just either get a dedicated buffer pedal and drop that first in line, or get something common with a buffer in it, something made by Boss or Ibanez or whatever. The potential problem with a booster that's also a buffer means that you're kind of limited as to where it should be in the signal chain, for both parts of the circuit to be usable how you need them to be.
  13. j5jarod777
    j5jarod777 Tele-Meister
    marysville
    Boss BD2
