Recomendations of a good, cheap pre amp
Discussion in 'Acoustic Heaven' started by fred4321, May 24, 2020.
  1. fred4321
    fred4321 Tele-Meister
    Wollongong NSW Australia
    HI,
    I have a KNA Piezo SG1 pickup on one of my guitars. Sounds good.
    I want to shape the sound better before it goes into my amp.
    A big ask, but can anyone recommend an inexpensive battery powered portable pre-amp (If that's what I need)?
    Mostly for practice.
    cheers
    PhredE likes this.
  2. haggardfan1
    haggardfan1 Friend of Leo's
    Texas, Louisiana, Texas again
    I have a Behringer ADI21 that fits your criteria pretty well. It's quiet, warm, has decent EQ, and only costs about thirty bucks.
    It isn't built as stoutly as something like the LR Baggs Para DI, but I have both and soundwise, the Behringer holds its own quite nicely.
    KyAnne, BB and PhredE like this.
  3. fred4321
    Thanks for that. The price is right!
    So, when it sits between the guitar and amp it will give me greater control of the guitars tone?
  4. haggardfan1
    Yes. It has a gain structure to set and then you can use the volume control on your guitar, if the guitar has one.
    It has a four band EQ, ground.lift, and a tube amp simulator that you can blend in to the signal or bypass altogether according to personal preference. Also very user friendly, at least IMO.
    KyAnne likes this.
  5. Charlie Bernstein
    Augusta, Maine
    If it's a passive pickup, browse used Fire-Eye Red-Eyes at Reverb.com.
    They're easy to use: nothing but a tone knob, a boost knob, and a boost switch (the red eye).
    And they get high scores for tone. Best of both worlds.
    I use one for a flattop, a couple of resonators, and a mando. They all sound great.
  6. Chiogtr4x
    Manassas Park, VA
    This is exactly how I use a Boss Blues Driver as an outboard preamp. Always ON
    It gooses my amp (s) with some presence and however much Level boost and ( adjustable) Gain I need, and I control everything from my guitar Volume knob!
    Easy Peazy! ;-)
    PhredE likes this.
  7. cravenmonket
    cravenmonket Tele-Meister
    Northern California
    I have one of these:
    https://www.lrbaggs.com/preamps-di/para-di-acoustic-guitar-preamp
    It's extraordinary, seriously. It brings back the sound of my acoustic guitar when I have to use a pickup (I have the Baggs M1). With a bit of tweaking, it's possible to shape the tone into a big, rich, warm resonance, which is why people like acoustic guitars, isn't it? It's truly an essential piece of equipment if you play live and want your acoustic guitar to sound "real".
    Edit: This pickup is magic, and designed to work along with the PARA DI.
    https://www.lrbaggs.com/pickups/m1-acoustic-guitar-pickup
  8. Dobronaut
    Dobronaut Tele-Meister
    Leicestershire UK
    I have an acoustic pedalboard with 3 of these, one for dobro, one for mandolin, and one for guitar. Inexpensive, and does the job. I just set the eq for each instrument and switch in and out as the setlist dictates. One lead in, one lead out.[​IMG]
  9. fred4321
    No,my pickup doesn't have a volume or tone control. Goes straight into the amp.
  10. black_doug
    black_doug Friend of Leo's
    Toronto, Ontario, Canada
  11. Brett Valentine
    Brett Valentine Tele-Meister
    Kent, NY
    Another vote for the LR Baggs Para Acoustic DI. For my large rig, I run a dual source system that allows me to soundshape a mic and piezo pickup independently. For a quick setup,
    I've tried Fishman, Boss, even ART pedals. I switched to the Baggs (around 2001) and I haven't looked back. I don't try to dial in a sound I like, just pull out problem frequencies with the notch (mid bass) and mid controls. I dial down any quackiness with the presence control, and dial in the lows and treble (think "air") to taste. The sound guys
    I regularly work with (these days mostly at church) have all said they really like the sound I feed them. It may not be on the same level as my large system, but for the most part, they run my eq flat for FOH.
    haggardfan1 likes this.
  12. KyAnne
    KyAnne Tele-Afflicted
    Swamps of Louisiana
    I second that !
    Brett Valentine and haggardfan1 like this.
  13. AAA71
    AAA71 Tele-Meister
    Ontario
    The JHS Clover is wonderful.
